Introduction: Raspberry Pi Pico 2W + Mobile App: Build Your Own Smart Wi-Fi Thermometer!
Have you ever wanted to easily monitor the temperature in every room of your house? The good news is that you can do it effortlessly for under ten dollars!
Step 1: Connect Temperature Sensor to PICO
Connect DS18B20 to the Raspberry PI Pico according to schema using a resistor between Red and Yellow wire.
Step 2: Set Up Visual Studio Code
  1. Install Visual Studio Code
  2. Open Settings -> Extensions
  3. Install Python, Raspberry PI Pico, MicroPico
Step 3: Connect to the Raspberry PI
  1. Open View -> Command Pallete
  2. Search for MicroPico: Connect
  3. Create a file main.py
  4. Add a line print("Hello") to the main.py
  5. When Pico connects, run All Commands -> Upload Project
  6. Press "Run"
Step 4: Clone a Raspberry PI Pico Framework
Run:
git init
git submodule add https://github.com/Nerdy-Things/itk_pico.git
Step 5: Broadcast Temperature to the Wi-Fi Network
Replace code in the main.py with:
from itk_pico.temperature import TemperatureSensor
from itk_pico.wifi import WiFi
from itk_pico.udp import Udp
from itk_pico.ip_utils import get_broadcast_address
from time import sleep
import json
UDP_PORT = 5468
temperature_sensor = TemperatureSensor(15)
wifi = WiFi()
udp = Udp(UDP_PORT)
wifi.connect("itkacher", "itkacher")
while True:
wifi.try_reconnect_if_lost()
temperature = temperature_sensor.get_temperature()
broadcast_ip_address = get_broadcast_address(wifi.get_ip_address(), wifi.get_subnet_mask())
message_dict = {"name": "Kitchen", "temperature": temperature}
message = json.dumps(message_dict)
udp.send(message, broadcast_ip_address, UDP_PORT)
sleep(10)
Upload the project to the Raspberry PI Pico 2W and press Run
Step 6: Clone a Cross-platform Application
git clone https://github.com/Nerdy-Things/raspberry-pi-pico-thermo-sensor-cross-platform.git
Step 7: Run the Application
To run a desktop application:
cd raspberry-pi-pico-thermo-sensor-cross-platform
cd kotlin-multiplatform
./gradlew run
To run an Android application:
Open the raspberry-pi-pico-thermo-sensor-cross-platform/kotlin-multiplatform folder in Android Studio. Press Run.
To run an iPhone application:
Open the iosApp/iosApp.xcodeprojfile in xCode. Press Run.
