Introduction: Raspberry Pi Pico -- 4x4 Matrix Keypad and 1602 LCD Interface
This experimentation uses RPi Pico, to interface with 4x4 Matrix Keypad and 1602 LCD. The Python program scans the Keypad at interval, and if a valid key press is sensed, then displays corresponding key value at 1602 LCD Screen
Visit the "VESZLE - The Art Of Electronics" you tube channel for further information and videos.
https://www.youtube.com/channel/UCY4mekPLfeFinbQHp...
The Matrix keypad
Step 1: Abstract
The Raspberry Pi Pico is a tiny, fast, and versatile board built using RP2040 features a dual-core Arm Cortex-M0+ processor with 264KB internal RAM and support for up to 16MB of off-chip Flash. It provides wide range of flexible I/O options includes I2C, SPI, and uniquely Programmable I/O (GPIO) pins.
In Embedded system design, matrix keypad (4x4, 4x3, 3x3 or 5x5) is used for key in the user inputs.
Similarly, character LCD displays [16x2, 16x4, 20x2 or 20x4 LCDs] are used for indicating the system status / parameters
This experimentation uses RPi Pico, to interface with 4x4 Matrix Keypad and 1602 LCD. The Python program scans the Keypad at interval, and if a valid key press is sensed, then displays corresponding key value at 1602 LCD Screen.
Step 2: Reference
Raspberry Pi Pico, Getting Started on Board Blink LED” Instruct-able / You-tube by PugazhM
https://www.instructables.com/Raspberry-Pi-Pico-G...
“Raspberry Pi Pico -- 16x2 LCD, 4Bit Mode Interface, BCD Counter” Instruct-able / You-tube by PugazhM https://www.instructables.com/Raspberry-Pi-Pico-G...
The “lcd_4bit_mode.py” driver library
Step 3: Component
Raspberry Pi Pico
Micro USB Cable
16x2 LCD Keypad Shield
4x4 Matrix Keypad
Step 4: Schematic -- 4Bit Mode - 16x2 LCD Connection
The 16x2 is very common type LCD, with two rows.
The “16x2 LCD Keypad shield” can be connected to Raspberry Pi Pico GPIO pins (GPIO0--GPIO6).
LCD operates at 4-bit data mode as given in above circuit.
If the display is not visible, adjust the Contrast pot (1K), to make it visible.
Step 5: 4x4 Matrix Keypad Interface
Matrix key pad can be arranged by push button switches in rows and columns.
In a simple technique, the 16 keys of matrix keypad are connected with 8 digital GPIO pins of RPi Pico.
Usually, the keypad scan procedure is Write HIGH to Row One. And keep rest of the Row to LOW.
Scan (Read) the Column One to Column Four, to find the key.
Repeat until a key press (are multiple) is identified. The key is decoded through Row selection / Column read.
The Row pins are connected to 8,9,10 and 11 of RPi Pico GPIO pins.
The Column pins are connected to 12,13,15 and 16 of RPi Pico GPIO pins
Step 6: Python Program – 4x4 Matrix Keypad Interface
As referenced above, download “lcd_4bit_mode.py” driver library
Open the RPi Pico as drive, and then copy the library into root directory
LCD is initialized and welcome screen of “RPi Pico 4x4 Matrix Keypad” is displayed in two rows, for about 5 seconds
The timer_one is initialized and callbacks the “BlinkLED” functionality for toggling on board LED at 200mS duration. (frequency = 5)
The timer_two is initialized and callbacks the “PollKeypad” functionality for polling the keypad at 500mS duration. (frequency = 2)
The “PollKeypad” function, first writes HIGH to Row One, and keep rest of the Row to LOW. Then scans (Read) the Column One to Column Four, to find out the key.
If the key is pressed, then the program detects the key press and displays corresponding key value at LCD screen
Demonstrates the use of Matrix keypad with RPi Pico. 4Bit mode LCD interface on Instruct-able and You-tube: https://www.instructables.com/Raspberry-Pi-Pico-16x2-LCD-4Bit-Mode-Interface-BCD/ https://www.youtube.com/channel/UCY4mekPLfeFinbQHpf9QcHg * The Raspberry Pi Pico pin connections for 16x2 LCD, for 4Bit mode are given below: # LCD Power Pins * 16x2 LCD VCC pin to VBUS * 16x2 LCD GND pin to GND # LCD Data Pins * 16x2 LCD D4 pin to GPIO0 * 16x2 LCD D5 pin to GPIO1 * 16x2 LCD D6 pin to GPIO2 * 16x2 LCD D7 pin to GPIO3 # LCD Control Pins * 16x2 LCD RS pin to GPIO4 * 16x2 LCD ENABLE pin to GPIO5 * 16x2 LCD BACK LIGHT pin to GPIO6
* The Raspberry Pi Pico pin connections for matrix keypad: * R1 pin of keypad to RPi Pico GPIO8 * R2 pin of keypad to RPi Pico GPIO9 * R3 pin of keypad to RPi Pico GPIO10 * R4 pin of keypad to RPi Pico GPIO11 * C1 pin of keypad to RPi Pico GPIO12 * C2 pin of keypad to RPi Pico GPIO13 * C3 pin of keypad to RPi Pico GPIO15 * C4 pin of keypad to RPi Pico GPIO16 Name:- M.Pugazhendi Date:- 20thJul2021 Version:- V0.1 e-mail:- muthuswamy.pugazhendi@gmail.com ''' from machine import Pin, Timer # Import time import time import utime import machine # Import lcd_4bit_mode import lcd_4bit_mode
# Initialize LCD pins RS = machine.Pin(4,machine.Pin.OUT) ENABLE = machine.Pin(5,machine.Pin.OUT) BACK_LIGHT = machine.Pin(6,machine.Pin.OUT) D4 = machine.Pin(0,machine.Pin.OUT) D5 = machine.Pin(1,machine.Pin.OUT) D6 = machine.Pin(2,machine.Pin.OUT) D7 = machine.Pin(3,machine.Pin.OUT) # CONSTANTS KEY_UP = const(0) KEY_DOWN = const(1)
keys = [['1', '2', '3', 'A'], ['4', '5', '6', 'B'], ['7', '8', '9', 'C'], ['*', '0', '#', 'D']]
# RPi Pico pin assignments rows = [8,9,10,11] cols = [12,13,15,16]
# Set pins for rows as outputs row_pins = [Pin(pin_name, mode=Pin.OUT) for pin_name in rows]
# Set pins for columns as inputs col_pins = [Pin(pin_name, mode=Pin.IN, pull=Pin.PULL_DOWN) for pin_name in cols]
#Initialize the onboard LED as output led = Pin(25, Pin.OUT)
#Initialize timer_one. Used for toggling the LED timer_one = Timer()
#Initialize timer_two. Used for polling keypad timer_two = Timer()
def BlinkLED(timer):
led.toggle()def InitKeypad():
for row in range(0,4):
for col in range(0,4):
row_pins[row].low()def PollKeypad(timer):
key = None
for row in range(4):
for col in range(4):
# Set the current row to high
row_pins[row].high()
# Check for key pressed events
if col_pins[col].value() == KEY_DOWN:
key = KEY_DOWN
if col_pins[col].value() == KEY_UP:
key = KEY_UP
row_pins[row].low()
if key == KEY_DOWN:
display.WriteLine(" ",2)
display.WriteLine("Key Pressed = "+ keys[row][col],2)
last_key_press = keys[row][col]# Initialize and set all the rows to low InitKeypad()
display = lcd_4bit_mode.LCD16x2(RS,ENABLE,BACK_LIGHT,D4,D5,D6,D7)
# Turn on Back light display.BackLightOn()
# Welcome string
display.WriteLine(' RPi PICO',1)
display.WriteLine('4x4 MatrixKeypad',2)# Wait for five seconds time.sleep(5)
timer_one.init(freq=5, mode=Timer.PERIODIC, callback=BlinkLED) timer_two.init(freq=2, mode=Timer.PERIODIC, callback=PollKeypad)
Step 7: Conclusion
The project is successfully completed with Raspberry Pi Pico, 4x4 Matrix Keypad and 1602 LCD Keypad shield
The program polls the key pad at regular interval and identifies the valid “key pressed event” Displays the key value at LCD screen.
Step 8: Video Link
Result_Video.mp4
Visit "VESZLE - The Art Of Electronics" you tube channel for further information and videos. https://www.youtube.com/channel/UCY4mekPLfeFinbQH...
If you enjoyed this instruct-able, then make sure you subscribe
The Matrix Keypad video link
