Raspberry Pi Pico -- Micro SD Card Interface
Intro: Raspberry Pi Pico -- Micro SD Card Interface
In this experiment, a "sample text file" is created inside the SD card, and then written with the running text. RPi Pico opens the “sample text file” for reading and dump the text on debug port.
Visit the "VESZLE - The Art Of Electronics" you tube channel for further information and videos.
https://www.youtube.com/channel/UCY4mekPLfeFinbQHp...
STEP 1: Abstract
The Raspberry Pi Pico is a tiny, fast, and versatile board built using RP2040 features a dual-core Arm Cortex-M0+ processor with 264KB internal RAM and support for up to 16MB of off-chip Flash. It provides wide range of flexible I/O options includes I2C, SPI, and uniquely Programmable I/O (GPIO) pins.
Secure Digital Card, abbreviated as SD Card is a non-volatile memory card, commonly used to write and read large quantities of data in smart devices. These days SD cards are available with 4GB to 128GB memory size.
The SD card module provides the micro memory card interface and it is connected to RPi Pico via SPI port. This experiment, creates a “sample text file” inside the SD card, and then written with the running text. RPi Pico opens the “sample text file” for reading and dump the text on debug port.
STEP 2: Reference
Raspberry Pi Pico, Getting Started on Board Blink LED” Instruct-able / You-tube by PugazhM
https://www.instructables.com/Raspberry-Pi-Pico-G...
The MicroPython “sdcard.py”
STEP 3: Component
Raspberry Pi Pico
Micro USB Cable
SD Card Module = 1 No
8GB micro-SD card = 1 No
STEP 4: Schematic
SD Card module provides “micro-SD card socket”, for inserting the memory card and then provides SPI interface pins (MOSI = Pin11, MISO = Pin12, SCLK = 10 and CS = Pin13), for connecting it into RPi Pico board.
SD Card module converts the +5VDC supply into 3.3VDC using AM1117, 3.3VDC regulator and converts the 5VDC logic Pins into 3.3VDC logic pins by using “74ABT125PW, Quad Buffer Tri state logic converter”.
The micro-SD card should be powered and operated with 3.3VDC. Otherwise, connecting the 5VDC logic into microSD card, can permanently damage the memory card.
This experiment uses an 8GB micro-SD card and it must be formatted (FAT32) on Windows 10 environment.
STEP 5: Python Program – SD Card Interface Module
MicroPython implements a Unix-like Virtual File System (VFS) layer. All mounted filesystems are combined into a single virtual filesystem, starting at the root /. Filesystems are mounted into directories in this structure, and at startup the working directory is changed to where the primary filesystem is mounted.
The main advantage of the FAT filesystem is that it can be accessed over USB MSC on supported boards without any additional drivers required on the host PC.
Download and store the MicroPython “sdcard.py” library into RPi Pico.
The file open functionality open(), can take following arguments for write, read and append a file.
w -- Open a file for writing the ASCII text. If a file is already existing, then it rewrites the file.
r -- Open a file for reading the ASCII text.
a -- Open a file for appending the ASCII text at the end.
wb -- Open a file for writing binary data.
rb -- Open a file for reading binary data.
MicroPython SPl, sdcard and os libraries are used for constructing the experiment.
MicroPython RPi Pico debug port is used for printing the debug statements.
During startup, the SPI bus and SD card is initialized.
Initially a “sample.txt” file is created / opened with FILE_WRITE option.
If file open is success, then the program writes running numbers (0 to19), into “sample.txt”, and then closes.
The program once again opens the “sample.txt” with FILE_APPEND option, and appends a text at the end.
Then the program once again opens the “sample.txt” with FILE_READ option, reads the “sample.txt” and send data to the debug port, which prints text on connected debug terminal.
# Demonstrates RPi Pico interface to MicroSD Card Adapter # Create a text file and write running numbers. # Open text file, read and print the content on debug port * The Raspberry Pi Pico pin connections for MicroSD Card Adapter SPI # MicroSD Card Adapter Power Pins * MicroSD VCC pin to Pico VBUS * MicroSD GND pin to Pico GND # MicroSD SPI Pins * MicroSD MISO pin to Pico GPIO-12 * MicroSD MOSI pin to Pico GPIO-11 * MicroSD SCK pin to Pico GPIO-10 * MicroSD CS pin to Pico GPIO-13 Name:- M.Pugazhendi Date:- 28thJul2021 Version:- V0.1 e-mail:- muthuswamy.pugazhendi@gmail.com '''
from machine import Pin, SPI import sdcard import os #Initialize the onboard LED as output led = machine.Pin(25,machine.Pin.OUT)
# Toggle LED functionality def BlinkLED(timer_one): led.toggle()
# Initialize the SD card spi=SPI(1,baudrate=40000000,sck=Pin(10),mosi=Pin(11),miso=Pin(12)) sd=sdcard.SDCard(spi,Pin(13))
# Create a instance of MicroPython Unix-like Virtual File System (VFS), vfs=os.VfsFat(sd) # Mount the SD card os.mount(sd,'/sd')
# Debug print SD card directory and files print(os.listdir('/sd'))
# Create / Open a file in write mode. # Write mode creates a new file. # If already file exists. Then, it overwrites the file. file = open("/sd/sample.txt","w")
# Write sample text for i in range(20): file.write("Sample text = %s\r\n" % i) # Close the file file.close()
# Again, open the file in "append mode" for appending a line file = open("/sd/sample.txt","a") file.write("Appended Sample Text at the END \n") file.close()
# Open the file in "read mode". # Read the file and print the text on debug port. file = open("/sd/sample.txt", "r") if file != 0: print("Reading from SD card") read_data = file.read() print (read_data) file.close()
# Initialize timer_one. Used for toggling the on board LED timer_one = machine.Timer() # Timer one initialization for on board blinking LED at 200mS interval timer_one.init(freq=5, mode=machine.Timer.PERIODIC, callback=BlinkLED)
STEP 6: Conclusion
The experiment is successfully executed with RPi Pico, SD Card Module, and 8GB micro-SD card
A “sample.txt” file is created, written with running numbers and then readback / printed the text via debug port.
STEP 7: Video Link
Result_Video.mp4
Visit "VESZLE - The Art Of Electronics" you tube channel for further information and videos.
https://www.youtube.com/channel/UCY4mekPLfeFinbQH...
If you enjoyed this instruct-able, then make sure you subscribe
The Micro SD card interface video link
4 Comments
CorK5 1 year ago
B45i 1 year ago
faysal180206 2 years ago
