Raspberry Pi Spy Tank
Intro: Raspberry Pi Spy Tank
I got a first prize from PI/E day contest. (yaayyy. Thanks for all the awesome voters!!!)
I would like to reward the first 10 people to contact me. I have 10 pieces of 3 month PRO membership codes to giveaway. Write a comment to this project or send me a message and tell me why you should get a free code. The best answer will get a free 1 year PRO membership! So in total 11 PRO memberships are given away!
Like, follow and vote ;) Thank you!
The prize pack included a GoPiGo kit witch is a good robot for beginners to experts.
However the basic model case is pretty clumsy and too tall to move around the house efficiently.
So i made my own case for the whole thing and basically build the whole bot from scratch.
This project requires some modifications to the original GoPiGo board.
STEP 1: Parts
The parts used are straight from the GoPiGo kit.
This includes:
-Raspberry pi B+
-Raspberry camera
-Two motors
-GoPiGo board
-Wifi Dongle
-SD card with GoPiGo image. You can download yours from here!
(Optional)
-LED's for light
-Cable
STEP 2: Printing the Parts.
The case is a remix of this project here.
Parts are printed with Printrbot makers kit.
Print material is PLA plastic.
Print speed varies from 20mm/s to 50mm/s.
Layer height is 0.2mm.
Total cost for all the prints were about 25 dollars. This was however made with a expensive PLA plastic that costs about 50 dollars/1kg. With cheaper alternative (look at ebay) You can get a half of the price down.
Parts check list. "aka" how many of what?
Bottom lid x1
Head x1
Sides x4
Tail x1
Track x52 (26/side)
trackFrame x2
Wheel x4
WheelGuard x4
STEP 3: Clean Up the Parts.
Clean up the exes plastic and check that everything looks like it should look.
Do a test assembly for the parts to see that everything fits.
STEP 4: Connect Camera
Connect camera to its own place. Use screws or hot glue to hold it up.
At this point you could attach the LED's to the holes if needed. I added the LED's lastly and it was pretty hard to get them there.
Note that the camera goes upside down to the head.
STEP 5: Assemble the Wheels
Assemble the wheels as show in the picture. Use hot glue or anything you like to ensure that the parts stay on its place.
Remember to test that the wheels turn without force. If you have to apply force to the wheel's to move them try sandpapering the parts until they fit perfectly.
STEP 6: Tracks
Connect the tracks to each other with toothpicks.
Toothpicks are cheap and work really well on the tracks. Note that the track's outer holes are smaller than the middle one. This is to keep the middle "hinge" loose when the toothpick is bushed through the smaller outer holes.
Use some force to push the toothpick to the track. Use small drill if needed to enlarge the outer holes.
STEP 7: Motor
Put some clue to the wheel hole to ensure that the motor stays in place. Push the motor shaft in to the hole and put some hot glue around the motor just to make sure it stays there.
STEP 8: Assemble Body.
Use hot glue to attach the side part and wheels to the main frame.
Glue only one side to the head and tail part.
If you glue both at the same time you will have a hard time to fit all the electronic parts inside.
STEP 9: Slim Up.
To slim up the GoPiGo board we will remove the unneeded parts. (the parts can be soldered back if you need them later)
Motor pins change the side from down to up.
Remove everything from the downside of the board.
This includes
-Two led's
-Servo pins
-motor pins.
-ISP pins
-IR slot sensors
STEP 10: Fit the Board to the Case.
The fit is tight. Watch out for the camera module!
Remove the side pillar for easy access if needed.
Connect the motors to positive and negative cables. If your wheels act all strange, change the positive and negative cables on the motors.
This would also be a good time to update the GoPiGo software and make the WiFi Dongle setup if you haven't done it yet.
Also try out the camera.
You can read from here about the update process of the GoPiGo image used
STEP 11: Rest of the Case.
Use a small amount of glue to the other side part. That just in case if you will have to fix something inside. The small glue will come off a lot easier than whole tube of glue put in there.
STEP 12: Tracks
Put the previously build tracks now on the wheels.
Put the tracks under the wheels and move the heads to the up side of the wheels.
Insert last toothpick to the connecting points and you are all done.
Make sure that the tracks and wheels spin easily. If not, make sure that everything is in line and smooth.
STEP 13: Case Is Done
The case is finally done. 2 days used to print all of these parts.
Inside the case is enough room for two 9V battery for stealth but quick run.
STEP 14: Run Program
To run the program you will need a SSH connection to your raspberry.
Make sure that the raspberry is on WiFi and find the IP address of the raspberry.
This is found from raspberry itself with ifconfig command at terminal OR via your own router setup site witch is your routers address. This address can be found from your routers manual or their website. Just Google
""insert your router name and type here" ip address".
After you are all set up. Download PuTTy and click SSH and type to Host Name your Raspberrys IP address
and click Open.
Now it will ask login name and password
Login name is: pi
Password is : raspberry
After that it should say pi@raspberrypi~#
To start the web server type:
This opens the folder the program is in
cd Desktop/GoPiGo/Software/Python/Examples/Browser\ Streaming\ Robot/
Then make the web server a executable file with
sudo chmod +x robot_web_server.py
And lastly start the web server.
sudo ./robot_web_server.py
Lastly type raspberrypi.local/ to your URL arddres bar on you browser
If that does not work use your raspberry's IP address to acces the site.
Now you can acces to the robot controls and live video with anything that has a internet connection and is in the same network.
STEP 15: Optional.
Attach the led's to the holes. Hook up them in series with 560 Ohm resistor. Connect the positive and negative wires to your battery lead wires. In the video the Led's were pretty dim because the battery was running out. When the battery was full they were really bright.
STEP 16: Bottom Lid
Push the bottom lid on to its place. This should just snap on. Easy to remove with flat head screwdriver.
Make a small hole to the corner if you are going to use bigger battery pack than the case can fit inside.
STEP 17: You Are Now Done.
The bot is now complete.
Play with it and see where it can go. Use the live video and bright led's to see under your bed and discover horrible mess from there.
For stealth approach use two 9V battery's inside the case in stead of that hudge 8 AA battery pack. I used that because i was running low on battery's and these had just enough power left to do the debugging and test driving.
Thanks for reading!
And Remember to vote and follow :)
48 Comments
docman100 5 years ago
heinv1 5 years ago
You missed the perfect opportunity to call it the Raspberry Spi
UbuntuLover 6 years ago
Cool project. Have you made any improvements over the last 3 years?
aditya.garg 6 years ago
the 3D print files
CardT 7 years ago
what app do you download on your phone or tablet
mkarvonen 7 years ago
CardT 7 years ago
hi thanks, im doing it for an engineering arkwight projet, and it needs to be portable and i saw you controlled iton a tablet. is this possible and if so how
As you can see in the video. The tank can be controlled with any computer/phone/tablet that has got a internet and a web browser. The how it is possible thing is simple. The Raspberry in the tank makes a web server that you simply access.
YashP35 7 years ago
Bruce JohnS 7 years ago
It's simple : when it turs left, only the right "track" ( side ) moves, and when it turns right, the same with the left side.
kylerelay 8 years ago
hello and great build!
i would like to build something similar but want to be able to securely control/stream over the net ....say from work to check on the dog.. :)
would i need other software or is this possible with the robot web server?
mkarvonen 8 years ago
It is possible with a VPN connection but it can be hacked if you are not careful. More info in here https://www.raspberrypi.org/documentation/remote-a...
:) if that is not what you are looking for then search google how to share your rpi with the internet.
AdjustedMold 8 years ago
Instead of the GoPiGo board, could we use a different RTK controller board?
Like this one here:
https://www.adafruit.com/products/1687
I don't see any reason why it would not work. However it may require a few alternations to the code.
Ajann 8 years ago
I will make one.
reidyst 8 years ago
Hi I was my son want to build this for a school project but we cant download the bottomlid.stl. the other files download but not that one any thoughts ?
thanks
sean
Hmmm. Strange. If i push the button it downloads instantly and works like a charm.
Try to download it again.
If it doesn't work hit me up and i can send it straight to your email.
reidyst 8 years ago
Thank you
adamwatters 8 years ago
This is damn cool. Just put together my own prize-pack GoPiGo yesterday and was thinking about ways to modify it. Great job!
