Introduction: Raspberry Pi - TCN75A Temperature Sensor Python Tutorial
TCN75A is a two-wire serial temperature sensor incorporated with temperature-to-digital converter. It is incorporated with user programmable registers that provide flexibility for temperature-sensing applications. The register settings allow users to configure power saving mode, shutdown mode, one shot mode etc.The sensor has an i2c compatible serial interface which can facilitate connection of upto eight devices in a single serial bus. Here is its demonstration with raspberry pi using python code.
Step 1: What You Need..!!
Step 2: Connection:
Take a I2C shield for raspberry pi and gently push it over the gpio pins of raspberry pi.
Then connect the one end of I2C cable to TCN75A sensor and the other end to the I2C shield.
Also connect the Ethernet cable to the pi or you can use a WiFi module.
Connections are shown in the picture above.
Step 3: Code:
The python code for TCN75A can be downloaded from our github repository-DCUBE Store.
Here is the link for the same :
https://github.com/DcubeTechVentures/TCN75A/blob/master/Python/TCN75A.py
We have used SMBus library for python code, the steps to install SMBus on raspberry pi is described here:
https://pypi.python.org/pypi/smbus-cffi/0.5.1
You can also copy the code from here, it is given as follows:
# Distributed with a free-will license.
# Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
# TCN75A
# This code is designed to work with the TCN75A_I2CS I2C Mini Module .
import smbus
import time
# Get I2C bus
bus = smbus.SMBus(1)
# TCN75A address, 0x48(72)
# Select configuration register, 0x01(01)
# 0x60(96) 12-bit ADC resolution
bus.write_byte_data(0x48, 0x01, 0x60)
time.sleep(0.5)
# Read data back from 0x00(00), 2 bytes
# temp MSB, temp LSB
data = bus.read_i2c_block_data(0x48, 0x00, 2)
# Convert the data to 12-bits
temp = ((data[0] * 256) + (data[1] & 0xF0)) / 16
if temp > 2047 :
temp -= 4096
cTemp = temp * 0.0625
fTemp = (cTemp * 1.8) + 32
# Output data to screen
print "Temperature in Celsius : %.2f C" %cTemp
print "Temperature in Fahrenheit : %.2f F" %fTemp
Step 4: Applications:
TCN75A is a temperature sensor that can be employed in personal computers and servers.It can also be deployed in entertainment systems,office equipments, hars disk drives and other PC peripherals.This sensor also find its application in data communication equipment.
