Introduction: Raspberry Pi - TMD26721 Infrared Digital Proximity Detector Java Tutorial
TMD26721 is an infrared digital proximity detector which provides a complete proximity detection system and digital interface logic in a single 8-pin surface mount module.The proximity detection includes improved signal-to-noise and accuracy. A proximity offset register allows compensation for optical system crosstalk between the IR LED and the sensor. Here is its demonstration with raspberry pi using java code.
Step 1: What You Need..!!
Step 2: Connections:
Take an I2C shield for raspberry pi and gently push it over the gpio pins of raspberry pi.
Then connect the one end of I2C cable to TMD26721 sensor and the other end to the I2C shield.
Also connect the Ethernet cable to the pi or you can use a WiFi module.
Connections are shown in the picture above.
Step 3: Code:
The java code for TMD26721 can be downloaded from our github repository- Dcube Store Community.
Here is the link
We have used pi4j library for java code, the steps to install pi4j on the raspberry pi is described here:
You can also copy the code from here, it is given as follows:
// Distributed with a free-will license.
// Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
// TMD26721
// This code is designed to work with the TMD26721_I2CS I2C Mini Module available from
import com.pi4j.io.i2c.I2CBus;
import com.pi4j.io.i2c.I2CDevice;
import com.pi4j.io.i2c.I2CFactory;
import java.io.IOException;
public class TMD26721
public static void main(String args[]) throws Exception
// Create I2C bus
I2CBus bus = I2CFactory.getInstance(I2CBus.BUS_1);
// Get I2C device, TMD26721 I2C address is 0x39(57)
I2CDevice device = bus.getDevice(0x39);
// Select proximity time register OR with command register
// Ptime = 2.73 ms
device.write(0x02 | 0x80, (byte)0xFF);
// Select wait time register OR with command register
// Wtime = 2.73 ms
device.write(0x03 | 0x80, (byte)0xFF);
// Select pulse count register OR with command register
// Pulse count = 32
device.write(0x0E | 0x80, (byte)0x20);
// Select control register OR with command register
// 100 mA LED strength, proximtiy uses CH1 diode, 1x PGAIN, 1x AGAIN
device.write(0x0F | 0x80, (byte)0x20);
// Select enable register OR with command register
// Set Power ON, proximity and wait enabled
device.write(0x00 | 0x80, (byte)0x0D);
Thread.sleep(800);
// Read 2 bytes of data from address 0x18(24)
// proximity lsb, proximity msb
byte[] data = new byte[2];
device.read(0x18 | 0x80, data, 0, 2);
// Convert the data
int proximity = (((data[1] & 0xFF) * 256)+ (data[0] & 0xFF));
// Output data to screen
System.out.printf("Proximity Of the Device : %d %n", proximity);
Step 4: Applications:
TMD26721 is an infrared digital proximity sensor which can be incorporated in Mobile Handset Touchscreen Control and Automatic Speakerphone Enable. It can also provide Mechanical Switch Replacement as well as Paper Alignment. Its high efficiency and reliability makes it suitable for various proximity sensing applications.
