Introduction: Raspberry Pi - TMP100 Temperature Sensor Python Tutorial
TMP100 High-Accuracy, Low-Power, Digital Temperature Sensor I2C MINI module. The TMP100 is ideal for extended temperature measurement. This device offers an accuracy of ±1°C without requiring calibration or external component signal conditioning. Here is the demonstration with a python code using Raspberry Pi.
Step 1: What You Need..!!
Step 2: Connection:
Take a I2C shield for raspberry pi and gently push it over the gpio pins of raspberry pi.
Then connect the one end of I2C cable to TMP100 sensor and the other end to the I2C shield.
Also connect the Ethernet cable to the pi or you can use a WiFi module.
Connections are shown in the picture above.
Step 3: Code:
The python code for TMP100 can be downloaded from our GitHub repository- Dcube Store.
Here is the link for the same :
https://github.com/DcubeTechVentures/TMP100...
We have used SMBus library for python code, the steps to install SMBus on raspberry pi is described here:
https://pypi.python.org/pypi/smbus-cffi/0.5.1
You can also copy the code from here, it is given as follows:
# Distributed with a free-will license.
# Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
# TMP100
# This code is designed to work with the TMP100_I2CS I2C Mini Module available in Dcube Store
# https://www.controleverything.com/content/Tempera...
import smbus
import time
# Get I2C bus
bus = smbus.SMBus(1)
# TMP100 address, 0x4F(79)
# Select configuration register, 0x01(01)
# 0x60(96) Continuous conversion, comparator mode, 12-bit resolution
bus.write_byte_data(0x4F, 0x01, 0x60)
time.sleep(0.5)
# Read data back from 0x00(00), 2 bytes
# temp MSB, temp LSB
data = bus.read_i2c_block_data(0x4F, 0x00, 2)
# Convert the data to 12-bits
temp = (data[0] * 256 + (data[1] & 0xF0)) / 16
if temp > 2047 :
temp -= 4096
cTemp = temp * 0.0625
fTemp = cTemp * 1.8 + 32
# Output data to screen
print "Temperature in Celsius is : %.2f C" %cTemp
print "Temperature in Fahrenheit is : %.2f F" %fTemp
Step 4: Applications:
Various applications incorporating TMP100 low power, high accuracy digital temperature sensor include Power-Supply Temperature Monitoring, Computer Peripheral Thermal Protection, Battery Management as well as office machines.
