Introduction: Raspberry Pi TMP112 Temperature Sensor Java Tutorial
TMP112 High-Accuracy, Low-Power, Digital Temperature Sensor I2C MINI module. The TMP112 is ideal for extended temperature measurement. This device offers an accuracy of ±0.5°C without requiring calibration or external component signal conditioning. Here is the demonstration with a Java code using Raspberry Pi.
Step 1: What You Need..!!
Step 2: Connections
Take a I2C shield for raspberry pi and gently push it over the gpio pins of raspberry pi.
Then connect the one end of I2C cable to TMP112 sensor and the other end to the I2C shield.
Also connect the Ethernet cable to the pi or you can use a WiFi module.
Connections are shown in the picture above.
Step 3: Code
The java code for TMP112 can be downloaded from our GitHub repository- Dcube Store.
Here is the link for the same :
https://github.com/DcubeTechVentures/TMP112
The datasheet of TMP112 can be found here:
http://www.ti.com/lit/ds/sbos473e/sbos473e.pdf
We have used pi4j library for java code, the steps to install pi4j on raspberry pi is described here:
You can also copy the code from here, it is given as follows:
// Distributed with a free-will license.
// Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
// TMP112
// This code is designed to work with the TMP112_I2CS I2C Mini Module available in Dcube Store.
import com.pi4j.io.i2c.I2CBus;
import com.pi4j.io.i2c.I2CDevice;
import com.pi4j.io.i2c.I2CFactory;
import java.io.IOException;
public class TMP112
public static void main(String args[]) throws Exception
// Create I2C bus
I2CBus bus = I2CFactory.getInstance(I2CBus.BUS_1);
// Get I2C device, TMP112I2C address is 0x48(72)
I2CDevice device = bus.getDevice(0x48);
byte[] config = new byte[2];
// Continous Conversion mode, 12-Bit Resolution, Fault Queue is 1
config[0] = (byte)0x60;
// Polarity low, Thermostat in Comparator mode, Disables Shutdown mode
config[1] = (byte)0xA0;
// Write config to register 0x01(1)
device.write(0x01, config, 0, 2);
Thread.sleep(500);
// Read 2 Bytes of data from address 0x00(0), msb first
byte[] data = new byte[2];
device.read(0x00, data, 0, 2);
// Convert data
int temp = (((data[0] & 0xFF) * 256) + (data[1] & 0xFF))/16;
if(temp > 2047)
temp -= 4096;
double cTemp = temp * 0.0625;
double fTemp = cTemp * 1.8 + 32;
// Output to screen
System.out.printf("Temperature in Celsius is : %.2f C %n", cTemp);
System.out.printf("Temperature in Fahrenheit is : %.2f F %n", fTemp);
Step 4: Applications..:
Various applications incorporating TMP112 low power, high accuracy digital temperature sensor include Power-Supply Temperature Monitoring, Computer Peripheral Thermal Protection, Battery Management as well as office machines.
