Introduction: Raspberry Pi - TSL45315 Ambient Light Sensor Java Tutorial
TSL45315 is a digital ambient light sensor. It approximates human eye response under a variety of lighting conditions. The devices have three selectable integration times and provide a direct 16-bit lux output via an I2C bus interface. The device contains a photodiode array, an integrating analog-to-digital converter (ADC), signal processing circuitry, lux calculation logic, and an I2C serial interface on a single CMOS integrated circuit to provide lux data. Here is its demonstrartion with raspberry pi using java code.
Step 1: What You Need..!!
Step 2: Connections:
Take an I2C shield for raspberry pi and gently push it over the gpio pins of raspberry pi.
Then connect the one end of I2C cable to TSL45315 sensor and the other end to the I2C shield.
Also connect the Ethernet cable to the pi or you can use a WiFi module.
Connections are shown in the picture above.
Step 3: Code:
The java code for TSL45315 can be downloaded from our GitHub repository- Dcube Store.
Here is the link for the same :
https://github.com/DcubeTechVentures/TSL45315
We have used pi4j library for java code, the steps to install pi4j on raspberry pi is described here:
You can also copy the code from here, it is given as follows:
// Distributed with a free-will license.
// Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
// TSL45315
// This code is designed to work with the TSL45315_I2CS I2C Mini Module available in Dcube store.
import com.pi4j.io.i2c.I2CBus;
import com.pi4j.io.i2c.I2CDevice;
import com.pi4j.io.i2c.I2CFactory;
import java.io.IOException;
public class TSL45315
public static void main(String args[]) throws Exception
// Create I2C bus
I2CBus bus = I2CFactory.getInstance(I2CBus.BUS_1);
// Get I2C device, TSL45315 I2C address is 0x29(41)
I2CDevice device = bus.getDevice(0x29);
// Send start command
device.write((byte)0x80);
// Send measurement command
device.write((byte)0x03);
Thread.sleep(800);
// Read 2 bytes of data from address 0x04(4), LSB first
byte[] data = new byte[2];
device.read(0x80 | 0x04, data, 0, 2);
// Convert the data to lux
int luminance = ((data[1] & 0xFF) * 256) + (data[0] & 0xFF);
// Output data to screen
System.out.printf("Total luminance is: %d lux %n", luminance);
Step 4: Applications:
The wide dynamic range of the ambient light sensor makes it particularly useful in outdoor applications where it is exposed to direct sunlight. The device is ideal for use in automatic control of street lights and security, billboard, and automotive lighting. The TSL45315 devices can also be used in solid state and general lighting for automatic control and daylight harvesting to maximize energy conservation. Other applications include display backlight control to extend battery life and optimize visibility in cell phones, tablets, and notebooks.
