Introduction: Raspberry Pi Zero USB Dongle
I’ve been trying to find ways to make better use of my raspberry pi zero and i think i have found one! turning your raspberry pi zero into a usb dongle and shared internet with your pc!
you can download and 3d print your own usb dongle shell
http://www.thingiverse.com/thing:1836302
what you need:
male usb connector
4 wires
some soldering skills
here is the diagram you need to follow to solder the male usb to the raspberry pi zero
Step 1: Config the Sdcard Image
I’m using the latest Raspberry Pi Image called Pixel which you can download here
and load the the image to the sd card. When you are done, located the file config.txt from the Boot drive of the sdcard and insert this at the end
[code]dtoverlay=dwc2[/code]
then save the file, and locate the file called cmdline.txt and insert this text right after rootwait
[code]modules-load=dwc2,g_ether[/code]
when done, save the file and you can now insert the sdcard into the raspberry pi zero
to access your raspberry pi from your computer, use ssh client and point it to
raspberrypi.local
now you should be all done!
