Introduction: Rattler Paracord Bracelet
How to make a Rattler Paracord Bracelet. You will need these Paracord Supplies, 10 feet of Paracord, and a Paracord buckle. You will also need a lighter and some scissors. Attach the Paracord to the buckles and measure it on your wrist. Learn How to sell Paracord Bracelets.
Step 1: Rattler Paracord Bracelet - 1
Wrap the first piece of paracord under neath the 2 center strands, back around and up through the hole that was made. Then pull it tight. Then below the knot you just made, do the same thing with the second piece of paracord. Wrap it around below, into the hole and pull it tight.
Step 2: Rattler Paracord Bracelet - 2
With the first piece of paracord, your going to do the same knot, but you will wrap it over the top instead of underneath. Then do the exact same thing with the second piece of paracord.
Step 3: Rattler Paracord Bracelet - 3
Remember to alternate over under over under. This will be the exact same as step 1. Wrap the first piece of paracord under neath the 2 center strands, back around and up through the hole that was made. Then pull it tight. Then below the knot you just made, do the same thing with the second piece of paracord. Wrap it around below, into the hole and pull it tight.
Step 4: Rattler Paracord Bracelet - 4
Now switch back to the top, With the first piece of paracord, your going to do the same knot, but you will wrap it over the top instead of underneath. Then do the exact same thing with the second piece of paracord.
Step 5: Rattler Paracord Bracelet - 5
Keep braiding until you reach the other buckle, remember to go over under over under each time. You can make 2 color paracord bracelet, just melt 2 pieces of paracord together.
Step 6: Rattler Paracord Bracelet - 6
Once you reach the other buckle, cut the ends of the paracord as short as you can, then melt them into the braid. Now you Rattler paracord bracelet is finished. Try more Paracord Projects, See the 9 Paracord Bracelet Patterns.
Sources:
Paracord Time.com
