Introduction: Decoding RC Signals Using Arduino
#ThugLifeRobot
Hey there folks,
Today i am going to show you guys how to use RC controllers and decode their signals for any of your projects
As many of the you know that we can directly use servo motors with RC receivers since, servos use PPM(Pulse Position Modulation ) signals as inputs to operate ,so by decoding the signals we can use RC receivers and transmitters to create a variety of wireless projects ..
So to demonstrate this we shall use a 4 wheel drive (4WD) robot .. to drive the wheels we are using four DC motors ,and they are controlled using a motor driver which operates on PWM(Pulse Width Modulation) signals. We will discuses the difference between PWM and PPM in upcoming steps.
So lets get started !!!!!
Step 1: Before Getting Started
Following are the materials required :
- Arduino uno (you can google it,there are plenty of places you can get it from )
- RC Transmitter (i am using flysky fst6 transmitter and receiver you can get it at various RC hobby websites for about 50$)
- RC receiver(i am using flysky r6b)
- Motor driver (i am using MD30 dual channel motor driver,i got this driver form 2krobotics.com for testing purposes ,they actually works great !!!)
- male to female jumpers
- 4 DC motors
- 1 Robot chassis (although not necessary -you can make one :) )
- 12 volt battery (we are using 3 cell li-po battery)
tools required
- screw driver (flat head and Philips screw driver)
Prerequisite
This tutorial is assuming that you are familiar with arduino development platform
Step 2: Difference Between Ppm and Pwm
PWM and PPM are two common words used in the R/C industry. PWM stands for Pulse Width Modulation and PPM stands for Pulse Position Modulation. Some devices that use PWM for control are ESC's (electronic speed controls) and servos. PWM is a technique used to relay data in the form of a varying pulse width.
You may be already familiar with binary, 1's and 0's; where a 1 is represented as 'on' and a 0 as 'off'. An example of this would be a light switch. Turning the switch on would indicate a 1, off a 0. In the case of a PWM/PPM signal, a voltage applied indicates a 1 and vice versa. However, in the case of R/C electronics this 'on/off' data is not enough, this is where the pulse width comes in.
The way we relay data to a servo for instance is the time the pulse is on. In the case of R/C electronics this time is usually around 1-2 milliseconds. A servo or ESC will monitor this pulse and begin counting when the pulse is detected and stop counting when the pulse stops. The time the pulse is on will determine the servo position. For example, sending a servo a 1ms pulse will make the servo swing completely left while a 2ms pulse will swing the arm completely right.
Generally in R/C equipment an entire PWM pulse will last a total of 20ms. The entire pulse is called a frame. A complete frame will include both the time the pulse is high (1-2ms) and the time the pulse is low. The image below represents a typical PWM frame.
Aside from the gaining servo holding power, the reason for the 20ms frame is just having the ability to line up several PWM signals in the same frame. Like I said before, the time the pulse is on is what is important because we are able to strip out this relevant data from a PPM frame to re-generate a PWM frame. For example, if a radio only sent 1 PWM signal at a time, it would take 20ms per channel. If you have an 8 channel radio each update would take 160ms. The same data can be packed into a PPM frame and only take 20ms per update. Transmitters and receivers are the two most common R/C devices that use PPM.
The following are lists of common devices that use PPM and PWM.
R/C Devices that use PWM Pulses:
Servos
Electronic Speed Controllers
R/C switches
R/C lights
R/C receivers
Data loggers
Failsafe's
Autopilot/Stabilization systems
Servo Controller
R/C Devices that use PPM Pulses:
R/C transmitters
R/C receiversAutopilot/Stabilization systems
PCTx
Step 3: Binding Receiver(RX) and Transmitter(TX)
following are the steps to bind RX and TX :
- Insert binding plug in the receiver's BAT port (if you do not have one you can use female to female jumper and connect pin 1 and 3 of RX together)
- Connect pin 2 and 3 any row of the receiver to +5V and GND of arduino (providing 5v supply to receiver )
- Power up the arduino !
- You will notice that receiver's light starts to blinking ,this shows that your receiver is not bound to any transmitter.
- Next, at the back of transmitter you will find the bind key,press and hold the bind key and switch the transmitter ON. Note :transmitter should be OFF for all the above steps and should turn ON ONLY after you press bind key
- Now if your receiver's LED status is a solid light then you have successfully bound the transmitter to your receiver.
- If all the above steps goes right then you are done lets head on !!!
Step 4: Wire It Up and Calibrate !
connect all the modules and components together (refer to image above for connections also listed below)
connections are :
MOTOR DRIVER -> ADUINO
- M1A -> arduino pin5
- M1B ->arduino pin6
- ENABLE1 ->arduino pin10
- M2A ->arduino pin7
- M2B ->arduino pin8
- ENABLE2 ->arduino pin11
- GND-> arduino gnd
- +5v ->arduino vcc
RECEIVER -> ARDUINO
- CH1 -> pin 3
- CH2 -> pin 2
- GND->GND
- +5V->+5V
attach motors to respective slots on motor driver
also power everything up by connecting battery to GND and VCC of motor driver
Burning the code
- download the attached file and open it in arduino ide
- select the board type (tools->board->Arduino uno)
- select the COM port (tools->port-> to the port your arduino is connected to )
- click on compile (to check any code errors ,though it is error free but it is good to check always ;))
- burn the code by clicking on upload button
Calibration time !!
- generally the PPM signal gives a value of 1000 to 2000 as we saw in PPM and PWM step
- but that is ideal value of an ideal remote(TX)
- so we need to calibrate it
follow the steps below to calibrate your remote
- after uploading the code to arduino and all wiring done ,click on serial monitor in arduino IDE
- note idle value and pen down the values of idle
- move throttle up and down and also pen down those values also
- in code to the top you can see " #define THROTTLE_SIGNAL_IN_PIN 2 " in line 2
- there pin 2 refers to pin connected arduino pin 2
- to check the calibrate the staring just change "2" to "3" after calibration for throttle is done
- repeat step 1,2 &3 for staring also
- now calibration part is done !!!
Step 5: Burning the Main Code
well then since we are done with the calibration part and we have our actual transmitter MAX , MIN and IDLE values for staring and throttle we are good to upload the actual code to arduino
we just need to replace these values to the values we got while calibration(i have use ideal values for referance purpose )
//stearing max min and neutral
#define SRC_NEUTRAL 1500
#define SRC_MAX 2000
#define SRC_MIN 1000
//throttle max min and neutral
#define TRC_NEUTRAL 1500
#define TRC_MAX 2000
#define TRC_MIN 1000
Step 6: Last Step
well the final step is ... to make something you like to build with this hack !!
hope you like it
comment below if you like it ,and also if you want any more elaboration on any topic related to this project ,feel free to ask
thank you for reading this instructable !!!
Arduino All The Things! Contest
Tech Contest
2 People Made This Project!
- Akshaynarisetti made it!
- Ferny152 made it!
34 Comments
Question 10 months ago
Hello
Unfortunately, I cannot find the motor driver (MD30 Dual Channel motor driver).
I got the motor driver MDD20A.
Can I use it too?
Sincerely, Arnulf Zapf
Question 1 year ago
At the part that says "Burning the code" it says to download the attached file, but I don't see any file in that section of the instructions. The only files I see are for the receiver test and the main code. Do we download the main code first, follow the rest of the instructions, download the receiver test code, follow those instructions, then finish by downloading the min code again? I am trying to figure out where I go from there. I have tried two different web browsers and have tried downloading the instructions, but I still cannot see any file in the "Burning the code" section. Any ideas?
3 years ago
Been looking for months for a simple solution to RC + L298N + Arduino.
Thanks so much!
Reply 1 year ago
were you able to use the code with the L298 driver without any modifications
Reply 1 year ago
Well hello after 2 years. Yes, it worked for me but I eventually went with the Smart Drive Duo 10 motor driver board with built in RC signal processing.
1 year ago
thanks so much !
1 year ago
Very good project but I'm a little confused.
As I see it your receiver does not support ppm and the ports you use is pwm..isn't that right
1 year ago
Thanks a lot, very helpful!
Question 1 year ago
How do I connect my Flysky receiver to arduino with l293d motro driver
2 years ago
Thanks a lot. very informative.
2 years ago
I don't know why but I always get the value around 6500, I think I should it get around 1500 but I don't know why but I always get it as 6500 when the switch is in on position and off
Question 2 years ago
Actually how is the connections of the motors made to the motor driver? actually i'm asking for four motors as your final image is a rc car of four wheels. If possible, share an image regarding the connections
Answer 2 years ago
there are 2 motors only
Tip 2 years ago
Thanks a lot! Great article
2 years ago
geeky singh pls resolve my doubt?
5 years ago
Awesome! I'm building a quadcopter, and this code works perfectly!
Reply 3 years ago
Hi,
i am building a quadcopter too. could you help with the build in a detailed manned?
Reply 5 years ago
Which motor drive did you use?
Reply 5 years ago
I used 1000kv brushless motors with simonk30A ESCs.
The motors arent branded.
3 years ago on Step 6
Thank’s. I was looking for a solution to the problem of the connecting APM controller with H-bridge.
