Introduction: Re-epoxy an Old Epoxy Floor
Instructions to prep and re-coat an old epoxy floor.
Step 1: Prep
Scrub the floor with TSP and rinse with water. Run a wire brush on an angle grinder over the surface to remove any old loose epoxy. Use a sanding pole to rough the surface with 120 grit sand paper. Vacuum the floor. Wipe with a damp rag. Vacuum again.
Step 2: Armorseal 1000 HS
Mix part A and B of epoxy in a 5 gallon bucket with a drill mixer. Apply epoxy in sections with epoxy roller.
Step 3: Flakes
Apply flakes to coated areas with a seed spreader.
Step 4: Rexthane
After the epoxy is dried apply a clear coat of rexthane with a mohair roller for extra protection.
