Introduction: Reaction Time Shooter
Hello everybody, I would like to share with you my new project: Reaction Time Shooter.
This game is to be played by one person at a time. The goal is to get your reaction time as low as possible by quickly shooting the target once the red LED turns on. Most people struggle to get a time below 300ms. I am eager to know what kind of times you are able to accomplish.
Gun:
  • IR LED
  • Push-button
  • Arduino Nano V3.0
  • 100 Ω resistor
Target:
  • IR receiver
  • 2x LED (any color)
  • Push-button
  • Arduino Uno
  • I2C LCD interface module
  • 16x2 LCD display
  • 2x 1K Ω resistor
General:
  • Wires
Step 1: Start Small
You have to start somewhere and this is where my journey started, with a simple IR LED hooked up to some code that made it fire every second. Before this point, I had never worked with Arduino or anything similar.
Step 2: Prototype Gun
This is all the setup you will need to have your own functional IR remote/gun. As you can see there is not much to it. Some of you might notice there is no resistor for the button. This is because I used the technique I discovered here. This not only makes the circuit easier but also adds a little trick to how you use the gun:
You see, the human mind expects a button to immediately react once it is pressed. However using this setup, the button will only fire once it has been released. This can be seen as a carnival trick to make it extra difficult to get a good time.
Step 3: Prototype Target
And this is all the setup you will need to have your own functional IR target.
Step 4: LCD Display
For simplicity and clarity, I decided to add an LCD display to an "empty" Arduino Uno. To combine both the target circuits simply connect the 4 wires of the LCD display to the other circuit. The library used by the I2C LCD interface module is available here.
Step 5: Code Gun
This is the code for the IR remote/gun.
Step 6: Code Target
And here is the code used by the IR target.
Step 7: Final Assembly
For my final assembly, I decided to use an old broken laser pistol I had lying around for my gun and I hollowed out a block of foam for my target. How you want to handle this step is totally up to you though.
Step 8: Play
Once you have it all configured and set up it is time for the most important part: play the game. I highly encourage you to challenge people to get a time below 300ms.
