Introduction: Book Lamp for Reading
Make a reading lamp that helps you focus throughout the day.Using the oldest hardcover you can find and make its best possible use!It was done as an assignment with a group of three .
Materials needed
- Hard cover of a book
- Aluminium sheet(optional)
- Ply wood
- Adhesive
- Bulb
- Wiring,Plug
- Translucent Sheet
Step 1: Hardcover and Base
Be it your oldest book you wanted to recycle or your favourite fictional character's novel which you have finished reading.Mark the dimensions of the cover on the backside of it for easy reference.
Then an outline of the base of the book is drawn which will rise up with the translucent sheet to give it a book shape.Care must be taken as this step is the most important.Wood must be cut along the outline which is made and then smoothened up using the machine or sand paper
Step 2: Translucent Top
The top of our book lamp must also be made as same as the Step 1.Just that it is being done with a different material.Translucent sheet must be cut through a blade which is made 'pointier' by the grinding machine as shown above
Step 3: More Work With Translucent Sheet
The drawing of the face of the page and the breadth of the book is to be drawn keeping in mind the dimensions of the book and the wooden base.
Scrape the translucent sheet along the drawing,best done with a ruler.
Step 4: Pasting Any Reflective Sheet(optional)
We have used a reflective sheet as we have used a 5 watt CFL bulb.Paste the sheets along the backside of the book
Step 5: Attaching the Bulb
The bulb must be attached to the wooden base using any object or material which affords support.We have used thermocol to make the bulb stand upright.Also for wiring ,a small hole is to be made using a cutter for the wiring to come out
Step 6: Stick Them All!
Firstly we must start off by sticking the vertical portions of translucent sheet to the wooden base with a strong adhesive followed by sticking of the top portion.Then all the wiring components and the reflective sheets must be rechecked if they are thoroughly stuck to the cover,this is because the book lamp is being closed and it cannot be opened again. Stick the hard cover Bingo ! Its done!
And then
"light it up"-Batman (the dark knight rises)
Budget(excluding wood and translucent sheet)
Adhesive - 40
5 Watt CFL bulb - 130
wires-30
plug and holder- 30
Total - 230 INR
