Introduction: Reading Spinners
What you’ll need:
A lettering plan
1 permanent marker, I used a sharpie and a paint pin
3 square beads, about an inch
2 end beads, any shape
1 dowel, cut to the length of the spinner
Hot glue for the end beads
Step 1: A Lettering Plan:
I used the word family list at :
http://www.enchantedlearning.com/rhymes/wordfamili...
to put together combinations of letters, to make words. You can use the ones pictured, or combine different letter combinations for your own child’s needs.
Each column is represents of one block, and one letter goes on each side of the block (except the nt goes together)
Write the letters on the square beads using the permanent marker.
Step 2: Assemble the Spinner
After writing the letters on the spinners, attach the first end bead to the dowel with hot glue.
Place the three square beads, in order, on the dowel. Do NOT glue them.
Carefully Glue the end bead to the end of the dowel.
