Introduction: Real Life Mario Block
Me and my students (9th grade) are transforming our middle school corridor into a real life Mario Bros Parkour thanks to radio connected Micro:bits.
For each light block, you will need :
- A cube of your choice,
- A Micro:bit
- A Micro:bit Grove Sheild
- A Grove LED strip
Step 1: Micro:bit to PC
Plug your first Micro:bit to your PC with the USB connector.
Step 2: Vittascience
In France, we use the Vittascience web interface to program Micro:bit. On Vittascience, all the libraries are already installed.
If you use Microsoft MakeCode instead, you must add the "Neopixel" library.
- Select "+Extension" (1) in the vertical functions list.
- Then select "Neopixel" (2)
Now, you can code.
Step 3:
Upload that code into your first Micro:bit by pressing "Télécharger"
You can go to the link to find the source on :
https://fr.vittascience.com/microbit/?link=615cbe84639f9&mode=blocks&simu=1
The algorithm is simple :
- Initialise radio channel
- Switch of the light.
- Wait for a signal to switch on the light ("A" pressed or "step1" radio message)
- Wait for checking to switch of the light and send the "step2" radio message to the next block.
- GOTO 3
If you prefer the MakeCode version, you'd better use this link :
Step 4: Plug the Light
Fit the Micro:bit into the Grove shield.
Plug the Neopixel strip to the P0 output.
Then plug the batteries
Step 5: Put Every Thing in the Cube
Put your electronic stuff in the first block cube.
Then suspend it to the corridor ceiling.
Step 6: Do It Again
From step 1 to step 5, do it again with the other blocks.
But you must change the radio messages in order to see your parkour enlight in the correct order.
- For the second block, replace A by "step2" and B by "step3".
- For the third block, replace A by "step3" and B by "step4".
- For the fourth block, replace A by "step4" and B by "step5".
And so on.
Until the last block where you will replace B by "step1" in order to enlight the first block again.
Step 7: Run
Press the "A" button on the first block to start the game.
Now put a red cap, run in your middle school corridor and hurt the blocks as they enlight.
