Introduction: Real Time Graph - Ultrasonic Sensor With Raspberry Pi
Plot Graph for Distance measured by Ultrasonic sensor v/s time using Plotly
Gathering data from sensor is cool. But lot of data can be confusing and it will be difficult to interprete how it varies. So how about streaming it , It is visually more understanding . Plot graph using Plotly! Its fun!
Step 1: Make Circuit
Things needed
1.Raspberry Pi 2
2. 2 resistors (330 ohm and 470 ohm )
3. Jumper wires
4. Ultrasonic sensor
5. wifi module
6. USB cable (to power pi)
7. BreadBoard
So to begin with make a circuit as shown in figure. Connect the GPIO pins as in figure. Make sure its right.
Step 2: SSH Into Your Pi
Once your done with circuit. SSH into your pi. I have used putty.
Login using your credentials.
Step 3: Create Plotly Account
Create plotly account. Its free!! once u create go to settings which appears on top right corner of screen.
Note down your username, api key and streaming key If streaming key doesn't appear click on add new token.
Step 4: Write Python Code
Write the python code for measuring distance from ultrasonic sensor. What the code does is , it gets the distance from ultrasonic sensor and plots it v/s time using plotly.
For code go to -- > https://github.com/sachinprabhu007/UltraSonicSensor_Rpi2
Clone or download the code and use it !
Make sure to mention your api key ,username and streaming token in code. You must change it accordingly.
use python file_name.py (i.e python ultrasonic_sensor.py in this case )to run the code .
Happy Streaming !! :)
