Introduction: Real Working Fan
Is it getting hot? Then you need to make this fan. Just point it at you and you'll be cooled down in no time. In other words you won't be hot.
1. Double aa battery holder
2. 1 long red positve wire
3. 1 short red poositive wire
4. 1 short black negative wire
5. Motor
6. Propeller
7. Double aa battery
8. Soldering Iron
9. Popsicle stick
10. Hot glue gun
11. Hot glue gun stick
12. S
Step 1: Getting the Battery Holder Ready
Put the battery in the battery holder and make sure negative goes to negative and positive goes to positive. Get the short red wire and short black wire and take some plastic off the front and back and the copper wires should be sticking out. Solder the red short wire to the positive side and the short black wire to the negative with the soldering iron. Make sure the copper wire that is sticking out touches the metal so it can get electricity.
Step 2: Get the Switch Ready
There should be 2 or more small pieces of metal sticking out. Get the long red wire take some plastic on each 2 ends and there should be copper wire sticking out. Solder one end of the long red wire to the one of the metal sticking out of the switch and the other end of the short red wire to the other.
Step 3: Getting the Motor Ready
There should be 2 small pieces of metal sticking out on your motor. Solder the other end of the black short wire to one of the metal sticking out of the motor. Solder the other end of the long red wire to the other piece of metal sticking out. Put on your propeller. If your propeller is to big then put hot glue in where you put the motor, put the motor, take it out. Now the hot glue should take up space for the propeller to fit.
Step 4: Putting Them in One Place
Get the popscicle stick and hot glue the battery holder at the back. Hot glue the switch to the battery holder. At the front hot glue the motor. If you haven't put the propeller on.
Step 5: Cool Yourself Down
Now you can switch on your fan and cool yourself down.
