Introduction: G Wagon - RC Scale Model
G wagon - True scale model
3D printed G wagon - 1/12 scale RC model.
A Performance RC model with offroad capabilities,
- Accurate 1/12 Scale
- Fully 3D printed (including shock absorbers)
- AWD power transmission
- Open Differentials
- Independent front suspension
- 30kmph Top speed
- 100% slope climbing
- Realistic Sounds and Lights
Designed in Fusion 360 and Sliced with Cura 5.1
G Wagon RC car
3d printing:
- PLA filaments - 4 colours ( 1 full spool of primary colour, the rest are 100g each )
- Flexible filament - for tyres
Hardware:
- 684 bearing - 23pcs
- M2 Screws:
- M2 6mm - 27pcs
- M2 8mm - 61pcs
- M2 12mm - 20pcs
- M2 16mm - 6pcs
- M2 20mm - 3pcs
- Ø2mm rod 14mm - 3pcs
- Pen springs - 4pcs
Electronics:
- Generic 2212 BLDC motor
- Brushless ESC (Blheli_S ESC recommended)
- 9g Servo
- 2S Lithium Battery
- RC Transmitter and Receiver
Required Tools:
- Screw driver
- Cutting Pliers
- Ruler
- CA Glue
- Hobby knife
- Soldering Iron
Parts spreadsheet: https://cryptpad.fr/sheet/#/2/sheet/view/AxR4jeach0K4OKKEAEVvadP1Ffx3YLsUh86SP9XW5To/embed/
Step 1: 3D Printing the Parts
The design looks best when printed with 4 colours, The used colours are are Orange, Black, Grey, White. Feel free to use your own colours, What colours do you like, Post your car photos in the Makes section.
All parts are printed with PLA. You need TPU for tyres and recommended for Side mirrors, they are more prone to breaking when printed with PLA.
Cura (5.0+) is the recommended slicer, Project files were saved with their recommended settings.
Some of the provided 3MF files have support blockers which may open as normal models in other slicers. You may have to manually assign them as support blockers.
Step 2: Assemble the Chassis
The chassis is an accurate design of the real model.
It has Independent front suspension and three open differentials. The shock absorbers are also 3d printed and use pen springs for suspension.
Download: Printables
Step 3: Assemble the Body
The Assembly of the body is simple, All the parts are glued together with super glue.
Headlights, Tail lights, Indicators can also be added.
Step 4: Sounds,Lights, More Info
Realistic Lights and Sounds were made possible by TheDIYGuy999 - Recommended as this adds a new level of realism to your model.
Available on github: https://github.com/TheDIYGuy999/Rc_Engine_Sound_ESP32
Notes:
- With a 3S battery, this model can reach upto 30kmph! before the gears start melting. So it is recommended to use 2S battery and low KV (1000-1400) motor.
- Lubrication is recommended for the gears.
Join our Revolt server for support and discussion: https://app.revolt.chat/invite/JacMpJHW
Credits: Car Body design derived from Shaylesh Roy's model, available at Grabcad
Looking forward to your feedback and suggestions ;)
