Introduction: Recording HD (720p) Video in Max 7
So you want to record your Jitter video output from Max 7 patches running on OSX in HD quality. In fact, let me make that more specific: you want your Jitter movies to be editable in a program such as Final Cut Pro X and viewable via QuickView in the OSX Finder. This is quite an understandable requirement if you are making a video art project using max/msp/jitter which needs some editing and post production. In this Instructable we'll edit an existing patch, but this works just as well for your own jitter patches where you need to generate 720p video.
Step 1: Record the Output From an Existing Patch
As an example, let's record the output from the Cycle-delic patch (see image). Open that one in Max 7.
Step 2: Make Sure Everything Generates 720p HD Video
In the example patch, the jitter matrix is restricted to 320 x 240 video. Although we can blow this up to 1280 x 720 HD, it would look quite pixelated. So we need to make sure all the parts that reference this small 320 x 240 format are changed to 1280 x 720. Most of it is in the [p stuff] object. After you've edited that one, it should look as the image in this step.
Step 3: Adjust the Center Pictslider
The second pictslider, labeled "Center", needs some different parameters now that it has to handle HD video. Set the value at Bottom to about 730 and the value at Right side to about 1290.
Step 4: Add Objects to Record Our Output.
The only output of the [p stuff] object is the jitter matrix we want to record. So this goes into a new [jit.record] object with dimensions 1280 and 720. Make sure the engine attribute is set at 'avf' and the codec to 'prores422'. We also need to add two messages: [write 25.] to write a movie at 25 frames per second (or change that to your desired framerate) and a [stop] message to stop recording video.
Step 5: Record Your Video!
By clicking on the [write] message box, a dialog opens where you can tell OSX where to save your new movie and under which name. You may notice that Max gets a bit more sluggish from generating video of this high quality. After the recording is done, you now have a prores422 Quictime movie in 1280 x 720 quality, ready for further editing.
So why the prores422 and not 4444? It appears that the latter can't be viewed via QuickView in OSX (i.e. hitting the space bar on a selected file in the Finder). If this is not a requirement for you, you can of course choose whatever codec you want. However, prores422 is easily good enough for silly art things rendered in jitter. On the last step, I will post the patch in Max clipboard format.
Happy patching!
Step 6: Max Code (File - New From Clipboard)
----------begin_max5_patcher---------- 4605.3oc6ck0aiajD9Y6eEbDlMHYhsRexifMASlDDr.Kv9RdLHqAkDkDioH4 RR4wSxl8291G7ThGszHRQZX+fbyljMq9qpt5qpp9Ou8lYKBd1Idl12p8qZ2b yed6M2HxhmwMoWeyrc1OuzyNV7XyVFramiexr6j2Kw44DQ9QNKChVo45qYf. gZ+ieJ6I72uy02yIQ75vhLC1mjkKHM2P6jkac827.qvRjDkAPeN3NMJV7OHE v+Gh8q1uk9RtqDe+fE+98HZ1GMN4SdNh7mwy3ut8V9O2oXcbmSbr8FmipieL xMwQCQmWacCUacC1bcSGhk0Mp3ehZHBUeUCix9lxxN4SgNxRY1r7m+yqV667 Q1W5nJ8u6lLOk4BQl.N6U68N9ab8czreZs16WFrxYoVXTPjSLAgNA9NpYrgZ H3z5DADgLaEbPfFAGF0+vN6jH2mmcWuCUgZwI6WutVDHSFecfeRr6eH91P3b KLw.CaUxYq6pUN9cHKkhWDcKw+PsAWDpJvU9axoXe6cRz5Ghbs8poUVYJyIJ E5RwNVQ3547jSTraP45wMyrCCKk8MkdENf+6AhBx3t7rb8kYAxyJx4I2CKVV 4FwvmDF3rORReOapOqnXXBrQ96cEuiLSFq+1rBLCRI.AjZHPTSXJvRJvTlTx lkAdRR5W0fBMTk+o7C5Er7QmUkI9YAgN9t9grlMLEp1Io0h7auxYs8dujGpH wvIoZt+Z6kNM9x0x7tY1lH2UA9bhnBOgmc1miUonR8tkqLhmv2NrlWlIdwvu FtYLqRtOdgcDmksPJ4fxtYRPfW0ak+ddNqSRucnqu+AnXRPXy2Lxcy1Vd2EA ratqsxVbm3G16Ku6CLU.IODa+TUzNw1yKUmP0h+YaeWV6ImDWIK.AxuoiuMq htMdYTfmWk5q7NOUycVwj1W57Q2UIaEenxBCrG2MLSHZVNWdk6Fm3jp4kXuI tZNG0Rlk09EosleHwYWnGqVT8ApLzgxMcKq8rR9soE83Ncj5gzVu3QMh1xs1 Q48+T9Upqalb0VG1rnCEvM2EUSpckMOv.YKdcxgpcOpmJXYZW0dqZWMbc8mc SVeZoJ2NSNjj.UBtqcDcMAaHKgpUL1P.XzreaD1.MTWKka1.SuzXvh8LcD9k +RUz5ypHlHLEeGKEhBrL4IHXH1.WsOfVQONzwFP0g8l.laZw+EXUaYc7fEjz Gqnd7TJpZ3PVR89.qrwaWcT2GxffVsJWuv1eSUo49QdsCMJAgGpIQ68r7dm1 6ex1igMzFkzQWGEKHCYCD4DEZSwBzbRoXoEFEa7PrANrRKHTY07pi5v1QcbJ dSE+SNV5VQciVQ8qONWclrUA56UVZ+xguTgtHDVfrPyNwW8QN91hbbrimFaL T8.H2gpCLQJ2JUgPL5Djocq6dTnzXOq+88JoTfM2ucoCMkgPrWmQ+2w+4c4o 9l7TecdJA6JK2c4IuuH4eKOE6KWj1947z1KJ9Z1Osob9qb4qMP50uoBc8lBx 4M2Wjr3y8E4o9u4o924o9e4o99uOO4e+uW71kd8h2+MEuUwKUj22UjYQxuqH 4aJR98gEOaXoRnT1kR+ckR+lRoiKAoKCJ.mD6h7sK+P1keJ6JOF6BT4Bda4R da4hdakxdakBeakBr3JmmCKmt3K4UPBdAaPku.BxuZ6mBCRxuJL3iET5+Ip3 FKcb8xuXsW.a7bYWEEr2eUQsHZu+x7qb23GvW1ie6rUvf6PAibTgP4f3gxkI oUMLjV0v35KpyGqjIzNhohIgMCT4ThObDWCtNcu.6U7tTYX3UXvIovttXsPM z6D0wS2NOiz9ge4m+vCwM28InufYnbkTSGysd2cehltvLeRQwKs8bV3ZGO1W kEDFKk+QcxRfuTlLjXyWBRrG67Fnoj2f6dhpfWJ7lTcTQAIWMkTPcoRpNmH0 TddTRXdMen.ePLWjKdGucrZkPrb4cQx9e6dwXpLgpQnFkovJqKW.RCphKrN4 khVE13ciBzZgSzaKNiDwo35MFgiLHgSbAeuFvbRvlMdNmw1WnDRI0Jz8Zii5 bxOi+I8rneT7pDNKz5R6dsBGPAxh8BmuqMMrInhJD+90C+wA6iVlQdo8QqUs 1sxINw0O2x.90hQPcvCVXhHkkTV4FyEfjaosRxJmJISTjjQpRx6bWEFvZRjB oP.YN8Nw+3beKq7qp9QGMUT99fMw3M7cNRCd17FK4hMKGBZkKPzz0g1j+bhq FqbswSKJrhjLYzPwHEoX7nghqoQZ8jLc7PxlppoENdnYiSQCzHglUtSXiwCM SORA9zflUBm0GOzLQUbdDo2P09SfimNTfp1iBbDoqCNA00Alf3rpcCdgnXse 61xlG9Ltk+t5AoUN+fcRRj6h8IxI.V1d2OIqwsI66diWvBauTavMelpsYxtE 106sE0iSz0F3qOX3Gc8Ww2U5KgmbfjNvCQtlIoKWBoAO3gPZ1MWjqb2YTkZx kkVGF2ZUTcW0.bFtpANcxRj17nIRt6znjWXbAAmcWErgXRTGaf8M1r1KfUWt P3.5jjQHhVMX41pYPZ0cd.s1loxJe01pKdRN5y5fnc1BhUeRArDcfx.K1ZxA rM3XZu4a3loCnc+Vru7LsTQYcwxkSrZEwMaDwYhL1ImnSoc4.v3PGmUdt63v 30.DyDakfnInUPzPAWEcfwOI26JBbXY+JHwRQ1DvQGoReNOGFo8ke4aWCu+s qQe06XUI5W80rjWSDEJLCGHocYQx3SVj6KdQWHj6b56Iy4mZ2euAcHKd20DA 0Vbg569bj7P5olCVqtDdy8cWse69B5Dt0axILEJRaUboAnPRsFhTa+ogZdy8 glQS4lba0Lpy43yHJwC9vJ6D6Ra1YtuZypIKjd8cgOXW7r52UrmEyBcWlD64 txQXLydtw7O+8FH1OP.62rG1nwGFhEaBnIaRkoOKe87yng7JGr39hEjK2Z.p 6AzSMwZwnRKZhAliHEjjXcPlsauWh6w0.zbC9elbuqyfMMWjdoWD25KhnDKd UGL2DpaYgK8hjVdQvbnNlMSI9Wj.nHjUQEBaUeEhOWJfAAhJdTBn9GkMRMKS HwPOcMPJV+lZX6nyjsaHX6PkX6F7MXbX35Djhbc3bJlZQNctdAuFLmWBbjn+ 35LkjrggCoJv0oywDnkIQEtN9r35PjvqALtbLczDgoCmqy+y3jY534P.gZPO 4l5.D1Tsl5VVrBVElN4rX5bZWGe4X4jIGKGNm0r0T2pGY4PFeTGXXh6lkyCj RVlHrRZ2omEK2hwi38Gp.KmyGfH5fvyA5u334HJvzRIdNzzf0otJ7b8wAOGM r7bzbhLFNvX.F.pooxChiJ5OuVYk1Y4VTBhHhZD5HfU49naQyNUmX.UQytIq T0sLPpvxMNuAwYxEzw.0X5bn8yu+bfJL8JLOkX5Es+FeLcV6bSKHisqT6bjA BSMUgoaNYX5vKLS2TDkVF8bcKDvDSTS6tkoAnzH2un6VZRfVRzmzR15nIWMf 3uUKNwNJQ6itIaE4yCTW6BhStSaom6xG44siGQHChXPg15nfchGQiUTh.y0c Zg16ic82nYuHXeBaRAZwNKC7WEydEs3.M6DMG6kay22BYLxYuLJ+fur6OYcq 6RpG2ZjtoEDYH1qg0cw3ZsUs+LGX+gU16z9kkasWjvPLF94tw021SSTs9LwO xbVSc9nQNU7SmxWucoqJm59TTRCvmdsv2OFrOxkI77ub9n1GB7V0uHovWX09 BMt6vNq2EunDo+jI1IRbqA1zd2L.ZJjmdo2sq5buNwFIjFLALacQcgWwcSnI YlGdn+kTvBvQZaDnVkTxCDWuHwA3I.Dl8dSlxcyeacQFNJ.ZoC482a.MDCci kh8e9zQJEC1lkgKYMqjE5YDj4pG5Y8nljM3tS17sfx.vrT4MxHeO+JHdmD12 jGBbDO+8RuHrAlRml2kBVSQey0vE7JFRCHhUqCAo5VeFbsLlEKEjU9z9lskF HytLbM7DfqYlBqLdkAeCUJm5D4ZTAKRrtAo+zu7Jh4EjWAu57pFiP7AI8eOD Hogd.KhaKszEgwjz.BqqVSwkp0zVMIi7Xp2zwp1p3G2prW5sYDA.4lnmNRyV OOAfMaPPU1u7gusD6y6DEN.C7zRpORFfiIvVQqqmsJGrxYvvBYnQnCn.z2PQ 1pm02ZVvx4kYf5VwxkxZYY0S2cLslkrIFVsKKK3Ux.P4gj1Ch2OCqWCfkFvn n6MyVsh1delOMd7WvvleLIxq90NwnmsyXI.AP0GtHpK1k7YuLBu.O0KXy9Qt lm5xyeEokmY85wdwqG6EudrWbQN1KDZDUJjwcRAKGcYbXERT7HU3TBakC6It PaAs7jsNI1ZuEN7gGKhEpnqWJJa0pOyS5iQPLHq7HHujA0oNBraDboIoR6N5 Y0d7h7ngVpTLzZjEy2j92waWC0dm1aWiX+xscO3WU9gqr0cnqkzud5V4Y7Yd ffLpCAeBX1IRCnoiLwM1Bgd1XMQIrNcuNL6DpMUN5ZeWMwatwYTUs1v8oZsA .8ba.iCNYblrGNH81o6TZfZVNirtGJR0S4iwyXMjKx10YvF.gTlQoUbpsAaz wQ3w39bnYA+rLfO6zqBRikS0ShzRksshzjILRa6ubaPzCe5p.zoZEj.szw6a EnQSef94qBPCkK9kx.MdBCz+QPvtqj7rzHTLfEmRDshxfo63gEAOh4WKDV5z qjtOBBaeB2U8f+wqv7URmg9oHLa8pr74AvpJKaLEDk6o0wLcnuptNl5mVzUu 6YWjt05iefJcjqpBTzK558J1x8wOFkMUTEwHxkVXZoCWZ5gOMAfpzgMpJTg6 In54I.TIGXhx6zxkFojC5cJHRoeJ3DrWvomGryuAqoWHMV0Hz834TMP43y83 IFLSmdgfYkO3DPStCNA334bH.gNkSUD33flgSOsbSw3It0D77dv7ReZ.Mhn4 QzA6yj7b0XpddOL0nY7DjlQSPZFN8NZoT+7dPexcdOX7548vYddOzjO0HWNl gv01sJhFtjVcoa891uFJG9ZtsjkRuyNZiqeYGRQXf0Mj8S1d6kXBxJqh6tyd iyN63GOvm0NNjJjDDdb4JIi7B1.mUtO5GrfS0Bx+WDj9OIMA9+I6NyCysepF 73G1WKuTYJHZwCCMA7P4QponjZpwfFXT49UoHfvbTsoISTSYepawia7WUe09 C7aUtdyIgZph8iinwWwoAvGWk93hrIC1pslLzIVSlbGE3B2h49hB9R1jonTa 9LZO00b6nICYz1jonN1yNVW7hqhe0k19Q5WcFsF9YtZ9UW7hlcqNbO6VcxPf kozs5ZEefu5VcM5VcFR+MGhMkptS2YD7qtU2qtU2qtU2kvs55KqYGRKGBDTX aLwWOqYuurhBoEKAU0d9GutVXesQ2ogsGUAH3jz2KWvCKhGXdhWY2RCIOn.0 UzoLMmxtIgL3TNtfeohgT327Ercix5x1d4ir9H0Zw5Q6MelMEmIR+OqaOBDn f8id2jvln2L9z4.M0OEcNSYWyZyHTmSZesppyQ+UcNmmNmTbVUcNFuXT4DUi JmgQzVFDnUUwxT1SDipSwx.o+fbJpOvup93LUePNEsGnIk1i9ZVjjSZRj89b HutVI83wNMMmdjrplH13xTzgJPwzomonimdlhNd5YJ53WME8OOSjVkVejImQ cimf14HX5YmiFSOybzZbQxpz7ybxYXlnWMLyyzvLa5DYJNIHr0CkIkCE95RK HiJmdlzSoaz1WTIlIWu0uHtc0oPHq+GJykhBsOkgVTySxelisrkijuNhanJ0 XnH0fFLpAp.0fGDpgPU.bHUFDw0mdp5NRGqe5RRODUnGqNvmctqBCb8SRaNg EGxdDKQ6WBQZH0UtBoKO9Fzs3Oo3pBZ3xU4Trgw.w5UrgAbPnFrR5vLOMFeJ +L8DMgJMd9pWgkluGkJjQDW0Cb9CH7FZ1CFLdOVIczVCG8nhZnCH5qO8P5n0 Q8RiXoKBPkFlwAWI80CpkvWBDW0GRiJoHhNbnMZb0IDFnJ2efvGEHGyAiZPJ ooFLBomSospob6ELo8RKPDdbIwW0I4UJ7azu7TknG7HidfCF8T0ATaYva5CC 4PUjbnCC4nR+avAaFnPrhjyvLRaHTQxYfDkUQS3YRMxEV4.2dgSHG3tKG3pK G6lKM6hKG5dKru7ec6+GgLFFB -----------end_max5_patcher-----------
