Introduction: Recording Audio for Videos and Animations: a Few Quick Tips and Tricks
If you're an aspiring artist, or just a kid that likes to occasionally make animations for youtube , you might have a couple of issues with recording the audio.
No matter how visually good a video or animation might be, if the people watching it can't understand what it says, your message might not get through to them. A good video requires a balance between audio and visuals.
A lot of things can get in the way of good audio for a video, wind, bad acoustics, low quality recording tools, and your own voice. But dont worry, I'm gonna show you a few tips and tricks on recording some good audio for little to no cost.
These tips just might help improve the overall quality of your videos and teach you a thing or two about producing.
This is by no means professional advice, just some advice from a kid who likes to make videos and reads from the internet a lot.
Step 1: Choosing a Room
If you're gonna record audio for an animation, the first thing you'll need is a recording room. Although a specialized room would be ideal, with a few tweaks, any regular room can become a quick recording room.
First thing you wanna do is look for a quiet and tranquil room to work in. Family members can create a lot of noise so if you feel they are interfering with your work, try closing some doors and windows and ask them politely to keep it down. Its a good idea to have things set up, and record when there's no one around.
When choosing a room its best to look for:
- Four walls
- Medium sized. A bedroom or small garage is good. Something bigger than a simple bathroom.
- A carpeted floor would be ideal, since it would absorb most of the sound. Concrete or tiles floors can also work, depending on the type.
- Wood doors
- Try to avoid hardwood floors, as they will reflect sounds too much.
- Glass windows can also mess with acoustics. If you have glass windows with fabric curtains, closing them might help the acoustics. (Plastic curtains might also help, but they still reflect sound to an extent.
- If you have a closet, the doors might also affect the acoustics if they occupy a large part of the room, but most of them don't have a significant effect. Some metal doors can reflect sound too much.
Step 2: Setting Up Your Room
Some of the following tips are from Albino Black Sheep member AvidLebon
Like I said before, if you're gonna record audio for an animation, the first thing you'll need is a recording room. Although a specialized room would be ideal, with a few tweaks, any regular room can become a quick recording room.
First of all, you can reduce the room's contribution to your recording by keeping away from the walls and by improvising screens using sleeping bags, pillows, blankets or duvets behind and to the sides of the recording artist.
The mic picks up both direct sound from the speaker and reflected sound from the room.
This will "deaden" the sound of the room when it comes to recording.
It's important to remember that hardwood floors and concrete walls make A LOT of noise! Sound waves hit those walls dead on and then rebound back into your microphone! And then they do it again! This is a common mistake among amateurs, as the room can seem quiet to you, while the mike picks up all sorts of noises you wouldn't suspect.
Some tips to prep a room for recording:
- Hardwood floors reflect sounds too much. If you have hardwood floors, it would be a good idea to put a towel or rug in a place where the floor is exposed. You might just have to put one rug or towel in the middle of the room, since this is usually enough to prevent the sound being reflected too much.
- Glass windows can also reflect sound. If you have fabric curtains, try closing them, since they might help reduce sound reflection. If you do not have curtains, putting a towel over the window or covering most of it will stop sound reflection.
- If there is too much noise coming from the rest of the house, even though the door is closed, try putting a towel under or close to the door, since air can still pass below the door, sound might also pass.
- If you have concrete walls and are willing to spend a bit more time, you can put two or three foam shapes on the walls, to try to distribute sound reflection, or at least reduce it.
Step 3: Equipment
The most important equipment you'll need is software and a microphone.
The microphone is the essential piece of equipment and your main tool. I don't have much experience in buying microphones myself, since I usually use someone else's. :D
Some tips on choosing a microphone:
I run my mic into a digital camcorder, which I can then firewire into computer. It takes longer to record twice, but is good quality on the cheap
You'll want to test out and learn these programs before you do your actual recording session, especially if you have other people doing voice overs with you.
There are many free audio programs for you to choose from such as :
Some good Software:
I highly recommend staying away from windows sound recorder. It's pretty low quality, and does not allow much customization. It's got a very small amount of output formats (I don't really know if it even does have any other output other than wmv.)
Microphone:
- Price is NOT consistant with quality for sure! A $30 average brand microphone might actually be better than a $90 brand name microphone, since these can have many unwanted or unnecessary options and features that can simply confuse the user.
- Avoid packages with little or no decoration. Chances are, if they didn't put that much effort into making it attractive, they didn't put much effort in the mic itself! (This is true for any piece of technology, I'm sure most of you agree with me!)
- The standard computer mic doesn't cut it for quality recording, and has a lot of 'wahwah' noise. I guess they could do if you want to do something quick and dirty, but if you want to make a high quality recording, its best to invest a little on a microphone.
- Be sure to check that a microphone is compatible with your computer. Some regular mikes have options for plugging it into multiple devices, but some can only be used with speakers. And you certainly don't wanna be surprised to find that your new $100 microphone is not compatible with your computer!
Software:
- Audacity - I only use this program, since it has proven to be more than enough for ALL of my audio needs. I've used it for music, sound effects, and general audio effects and editing. It's got a pretty full arsenal, and some good voice filters. I highly recommend this program.
- Goldwave -
Some good Software:
Step 4: Tip: Pop Shield
When recording, you will probably notice that 'popping' sounds like P and B will sound horribly bad and can ruin the animation. Chances are these sounds can't be fixed in the recording. To solve this problem, use a Pop Shield
A Pop Shield is a tool you put between the mic and the person recording. A Pop shield can be compared to a water filter. Like the water filter holds anything in the water that's too big or solid, like iron bits from the faucet, the pop shield filters the sound.
Pop noises like P or B make you spit out saliva and lots of air. The pop shield holds these unnecessary noises and only lets the sound through.
You can buy a Professional Pop Shield.......Or make your own for free!!:
To make a Pop Shield you'll need:
To use, just hold it between your mouth and the mic. You could use a wire coat hanger, and then wrap it around your microphone so you don't have to hold it.
Another quick method is to simply stretch and hold a stocking in between you and the mike.
- Wire Coat Hanger
- Stocking or one of those black or brown socks that are really thin.
Step 5: Outdoors
Recording sound outdoors can cause your voice to sound low and unclear because of all the noises like cars, kids or animals. The wind is also a huge problem, as it will mess with the waves of your voice.
Video cameras generally have low quality audio recording, although there are some exceptions. If you're gonna make a video outdoors, its a good idea to record audio with a separate device and then intertwine the audio with the video.
Professionals use special microphones that cancel out undesired noises, but unfortunately chances are you can't afford one of these, so you probably wont be able to totally prevent wind from appearing in the audio in very windy areas.
A pop shield might help reduce wind interference. Make a Pop Shield around the microphone, or if you have some extra cash, use some foam around it. Professional sound recordings use this technique, albeit they use special foam. Make sure that sound can pass through the foam you use. You don't want it to block all sound, just reduce wind interference.
Step 6: Actual Recording
A few tips while recording:
- If your are reading from a script, have it laid down somewhere, because when you move it, paper makes crinkles background noise, which is what we're trying to avoid. Or even better, tape it somewhere at eye level behind the mike, so its easy to read, and the person wont have to keep looking up and down! (Thanks Yokozuna!)
- Keep the mike at 45 degrees from you.
- Keep the mike away from fluorescent-light fixtures, computer air vents, and any other sources of noise you might have. (You might not notice it, but it will probably show up in recording as an annoying pitch sound)
- If you have noise that you can't trace to a source, it may be that the mike is picking up vibration from the surface the stand is sitting on. Try setting the stand on a surface that isn't vibrating, or try putting a cushion of some sort - maybe a mouse pad - between the vibrating surface and the mike stand.
- Try to keep the microphone away from your computer tower, as that itself makes noise.
- Are your computer's speakers turned off? If they are on, you can get feedback (a painful screeching noise) during your recording with a microphone. If you're on a PC, your speakers can also be disabled in the Windows Volume Control, if you cannot easily turn them off.
- From Yokozuna: While this may seem a bit cheesy, you normally want to smile as you read, it generally makes the audio sound "warmer"
Step 7: Portable Voice Recording Booth
A little piece of portable awesomeness, the Portable Voice-over Booth is a must for every artist or videomaker who is truly dedicated to his work, and has some spare cash.
It's a fairly useful little box, that provides enough space for comfortable voice recording and can be neatly folded down to take anywhere.
A decent laptop, an audio interface, and a microphone allow you to record and deliver voice tracks from almost anywhere. And with high-speed Internet readily available there's no reason to miss sessions and auditions because you are on location or vacation, unless you choose to.
This setup allows you to make high quality voice recoding on the go. In fact, it may be a great setup for anyone that needs to record voiceovers and doesn't have a lot of space. This would be great to use while documenting your next project!
Step 8: More Tips
Well, that's all I got. How about you? Got any other tips that might be useful to those who read this? Leave a comment and I'll post it here!
Yokozuna says: Most good mics are not compatible with computers, they would have an XLR out. Computers can be set up to accept XLR, but it's quite expensive.
