Introduction: Rectangular Lifting Magnet
About: Electro Flux Equipments is head quartered in Chennai with manufacturing unit, established in the year 2005 and since then has consolidated its position as a market leader in Design, Manufacturing and Marketin…
Electro Flux Rectangular Lifting Magnet mainly used to lift heavy sheets, plates, Rounds or Square bars, bundles, billets, ingots and many similar applications, in shipyards, steel mills and foundries. the magnet makes direct contact with the surface, as a gap of as little as 1 mm can cause a 50% reduction in lifting capacity.
MODEL NO. SIZE OF MAGNET POWER INPUT KW WEIGHT OF MAGNET
EF RLM 1 1370 * 470 110 V 2.6 1050
EF RLM 2 1500 * 500 220 V 3 1250
EF RLM 3 1800 * 550 220 V 4.2 1450
These Rectangular Lifting Magnet can be used individually or in multiples with different types of suspension systems. The correct choice of system depends on the following factors:
The structure and function of the crane
The type of traverse fitted
The shape and surface of the material to be lifted
