Introduction: Recycle the Electronic Ballast From Compact Fluorescent Lamp (Reciclar La Balastra Electronica De Un Foco Ahorrador )
Hi ! in this instructable we are going to recycle the electronic ballast from a CFL
Hola , en este instructable vamos a reciclar la balastra electronica de un foco ahorrador
Step 1: The Material and Tools
The things that you will need are :
MATERIAL
1 Fluorescent tube (it depends on the power that you want , in my case I used one of 15 watt )
1 Compact Fluorescent Lamp (If the tube that you want to drive is 15 watt , you will need a CFL of 15 watts or more )
TOOLS
These are the most common
Wire
Screwdriver
Soldering and soldering iron
Cutting pliers
Las cosas que vamos a necesitar son :
MATERIAL
1 Tubo Fluorescente (Depende en la potencia que necesites , en mi caso use uno de 15 watt)
1 Foco o Lampara Ahorrador (Si el tubo que quieres usar es de 15 watt , vas a necesitar un foco ahorrador de 15 watts o mas )
HERRAMIENTAS
Estas son las mas comunes
Cable
Destornilladores
Soldadura y cautin
Pinzas de corte
Please be careful of touching the ballast pcb ,by the capacitors , try to insolate the conections and pcb
(Por favor tenga cuidado de tocar el pcb , por los capacitores , Procure aislar bien las conexiones y el pcb )
Step 2: Open and Remove (Abrir Y Remover)
With the flat screwdriver pry the base taking careful not to break the glass , then cut the wires from the ballast to the tube and the ac mains wires , dont open the lamp if it is conected to the AC mains , also remove with the soldering iron the connections in the pcb that are conected to the tube.
Con el destornillador plano abra la base con cuidado de no romper el vidrio del tubo , despues corta los cables de la balastra al conector E27 y los cables de la balastra al tubo , tambien desolda los conectores en el pcb que estan conectados al tubo
Step 3: Wire Everything in to the Tube and Wire the Plug That Later Will Be Conected to Ac Mains (Conecta Todo Al Tubo Y Al Enchufe Que Sera Conectado Mas Tarde)
Before conecting the plug to ac mains wire everything and make sure you had insolated everything and you will not touch the pcb.
Solder wires to the tube and to the ballast , and prepare to test it , before check everything is well insolated.
Antes de conectar el enchufe a la luz conecta todo y asegurate que hayas aislado todo y no vas a tocar la pcb
Solda cables al tubo y la balastra , prepara para probarlo , primero checa que todo este bien aislado
Step 4: Test It and a Video (Probarlo Y Un Video)
Congratulations the project is complete just test it
Felicidades el proyecto esta completo , solo pruebalo
![Timer for Light Fixture [Temporizador De Apagado De Lampara]](https://content.instructables.com/F5D/VO9A/JJEJXRHK/F5DVO9AJJEJXRHK.jpg?auto=webp&crop=1%3A1&frame=1&width=130)
