Recycled Crayons
Intro: Recycled Crayons
Since I have so many used crayons in my house from my sister and I growing up over the years, I felt that their should be a use for old crayons. Continuously being bought around school time sales, I was clueless of what I would do with the older crayons that are now broken and worn. I decided on donating the finished crayon molds to a Hospital for children so they have a fun activity to do while being treated in the hospital. It is a very fun craft to make but at the same time it makes it even better knowing you are making another child happy.
STEP 1:
Gather all your supply's. Most familys especially with children have buckets and buckets of broken old crayons. Turn them into something colorful and alter its shape. Not only will you be getting rid of your old dull crayons but you will be able to use them to create new crayons! You will need:
-Several broken, used crayons
-Heat source
-Candy molds (small- medium sized) (Get fancy and use different shapes. example: hearts, circles, squares, )
-Adult to help to supervise
-Heat source
STEP 2:
Next, peel each individual crayon. This part leaves it up to the maker to combine different colors. It is helpful to break the crayons up into small pieces as shown below to help the wax melt when ready to melt. As you are filling up the candy molds remember that you can use more than one color crayon in the mold to create a swirly colorful effect when popped out. See below for example.
*Notice the crayons are not too big or too small.*
STEP 3:
Now, with a trusted adult preheat the oven to 270 degrees Fahrenheit. Once preheated place the mold into the oven. Frequently, check the oven to see the progress of the melting wax. Don't be afraid if the wax turns a dark brown or gray on the surface. Underneath is a work of art. DO NOT GET ANY WAX ON THE STOVE AS IT COULD LEAD TO A FIRE. AS SHOWN BELOW, WAX GOT ON THE STOVE AND IT LED TO A HOUSE OF SMOKE.
*I cannot stress enough how dangerous this could be if wax gets inside the oven. Please use at your own risk and be very careful!*
STEP 4:
Now that you have your crayon wax filled mold, you are now ready to let them cool. Set them on the counter with something underneath so the counter wont burn. after 15 minutes check the wax to make sure it is dry enough. Check with an adult and make your own judgement when you think the wax is ready to be touched. If you are unsure if the wax is dry enough, let it sit out longer . If the mold is not dry enough the completed project with most likely crack or melt. Once you are sure that you are ready to see your finished project, pop the wax out of the mold
Start coloring! *Be safe and have fun!*
3 Comments
ortega05 9 years ago
Great summer activity, place the molds outside and the hot sun will melt the crayons, did this when teaching Pre-Kinder. It might take a little longer but it is a lot safer.
Gobie 9 years ago
I like that you can use any mold
Babyshoes 11 years ago
Also, though it may be common sense and is clear from the photos, you may want to emphasise that the moulds need to be metal or oven safe silicone - many candy moulds are plastic which would melt.
