Recycled HDD Rotary Sander for $5
79,851
245
130
Introduction: Recycled HDD Rotary Sander for $5
About: M.H.Kabir is a green geek who likes recycling and loves instructables and DIY among other things such as microcontrollers, embedded systems and photography. He has done many DIY Green tech projects!He is a stu…
https://www.instructables.com/id/Recycled-HDD-Powertool-Disk-of-Prometheus/
The new instructable is here. Its ia newer, improved and hugely better version and adresses the disadvantages of this design
 If you are a computer guy, you must have lots of Hard Disk drives piling up. If you want to use these for a good reason, the HDD Sander is just for you.
Because of the high RPM platter motor , the HDD platters have enormous speeds, generally from 5000  RPM up to 15,000 RPM. To make use of this power, The HDD Sander attaches directly to the platter, in a portable and interchangeable design.
A quick video of the HDD Sander in action is below.It was taken in the dark and looks excellent, due to the sparks coming from the sander.
WARNING: The HDD sander is not a plaything. The platters are spinning at a very high speed, making it easy for the sander to rub your finger raw. I am not responsible for any damage you do to yourself or to anyone else near you.
UPDATE 1: Some users have pointed out to me that their HDDs are just not simply spining up. To make them, sometimes you need to adjust the jumper blocks on the back of the HDD.See Step 4, Picture 1 for help.
Step 1: Materials
 Most of the materials for this project have been recycled to keep the cost down.
1.An dead HDD - From a old Presario ($0)
2.Sand paper(any grit) - $5
3.A bench-top Power Supply/12v power source - ATX conversion ($0)
(Search for "ATX bench-top Conversion" on instructables)
4.Molex Power Connectors - $0 (recycled from old PSU)
Thats it, thats all you need for the HDD Sander. I expect you to have a few basic tools like a pair of scissors and a wire stripper and a screw driver with a Torx T9 driver head.
You'll also need an compass to make the sand paper template.
Step 2: Dissasembling the Hard Drive
Thats the boring part done, now lets start voiding some warranties.The model we will be dissasembling is an old Seagate.
Firstly, make sure the HDD can spin up by connecting it to an computer and listening to the spin-up.If it spins up, continue, if not, check the power connectors.
Start by peeling off all the stickers on the body of the HDD. Particularly the ones with "WARRANTY VOID IF SEAL IS BROKEN"
This will make all the Torx screws visible.
Unscrew all of them, on the side with the steel shield which protects the HDD. Don't unscrew other side, the one with the PCB. We will require the PCB side for the HDD motor controller.
Even after you unscrew all of the screws, it will seem as if the shield is still attached to the body.Inserting a flat blade screwdriver head into a gap and pry it open, very gently.
After doing this, put the shield away and behold the guts of an HDD.
You will see 3 things. The HDD platter, the actuator head and the powerful rare-earth magnet.Unscrew the magnet from the body and keep it for future projects.Also, slide out the actuator head and also store it.
Now that we've finished disassembling the HDD, you can now only see the dominant HDD platter. That is he most important aspect of the HDD Sander.
Step 3: Cutting and Fitting the Sand Paper
 The sand paper needs to be cut down to the size of the platter so that it can easily fit into its place and can be removed if necessary.
The technique used to cut the template from the sand paper is simple. Firstly, use you compass to find the disance from the centre to the edge of the platter.
Then, use the compass to draw the circle on the sand paper.
Do the same for the inner circle, and find the distance between the center of the steel disk and its outer edge. If you are confused, see the pictures for help.
Then, with a pair of scissors, cut out you template and check if it fits on the platter. Trim the edges as necessary and don't keep too much slack on the center edge.
After trimming, gently ease the sand paper onto the spindle(see video)
Step 4: Finishing It All Up
To test whether your HDD sander works or not, you will have to cut the Molex connector,strip it and connect it to your PSU/power source. connect the Molex as shown below.
 RED     BLACK     BLACK    YELLOW
 +5v         gnd           gnd         +12v
Plug the Molex Connector into your HDD, turn on your power supply and watch it spin up.
If you are using an alternative power source, remember that you will need to give exactly 5v and 12v to the Molex.Otherwise, the HDD's controller will not start due to power deficiency.
You will also need to supply about a total of 2 watts to the 5v and 12v lines.The wattage depends on the RPM of the HDD motor.Generally, this rating is printed on the large sticker covering the metal RF shield.
That is why this project is much easier with a benchtop variable voltage PSU.
The PSU can provide the HDD the current it needs by monitoring the current draw of the HDD.
Picture 1 courtesy of  'www.pcguide.com'
Step 5: Tests: Grinding
TEST 1 : GRINDING WOOD
The sander performs very well and smoothens down the wood quickly.See video for the demonstration.
TEST 2 : GRINDING STEEL
The sander effortlessly grinds through the steel, although better performance would be reached with specific, black steel grinding sandpaper found here: http://www.hartvilletool.com/shared/images/products//large/29887.jpg
Step 6: Tests: Sharpening Knives
With the high RPM HDD Platter, you can sharpen knives easily.
The folllowing videos show 3 stages: before grinding, being ground, and after grinding. The end result is quite pleasing.
BEFORE GRINDING:
GRINDING:
AFTER GRINDING:
P.S - The 2nd video shows and good technique of sharpening the knife if you have never sharpened one before.
Hope you enjoyed. Post lots of pics if you decide to build one and don't forget to clean the sander's insides with a fine camel-hair brush, once in a while after using it.
If you like it, subscribe to me for some interesting builds. Rate me too :)
Kabir
1 Person Made This Project!
  • Big and Small Contest
  • For the Home Contest
  • Game Design: Student Design Challenge
130 Comments
Schotte
Schotte
6 years ago
I m trying to build one myself, but my HDD spins up for 10 seconds, stops and starts again for 10 seconds. Do I need a jumper somewhere so it continues spinning? I also tried a different power supply, same result.
I got an ide hdd if that matters somehow.
Go JunN
Go JunN
6 years ago
Is there a way to bypass R/W heads to make the HDD Motor to spin without it because I think that the Built-In Circuit Board (Motor Controller w/ Data Interpreter) requires the response of the head, Thank you in advance, Nice Idea thou :D
Treknology
Treknology
12 years ago on Step 5
This is a nice little idea that would be fantastic for squaring off the ends of acrylic tubing--but what tests do you perform on the drive before ripping the heads out to make sure that it will keep spinning rather than shut down and register an internal fault?
mhkabir
mhkabir
Reply 12 years ago on Introduction
 I just ran it continuously for half an hour or so and tried different jumper combinations.
dadu2007
dadu2007
Reply 6 years ago
Se para a los 10 segundos,cual sera el problema
chibby0ne
chibby0ne
Nice experiment. Im trying it myself. I'm using a IDE HD but it won't stay on for more than 10min, I don't know the model nor brand that I'm using, It has 10 jumpers pins and I've tried Slave, Master and Single, only one left is PM2 and some pair that doesn't say anything below. What do you think the problem might be?
mhkabir
mhkabir
Could you please post a picture of your HDD jumper combos. Maybe your PSU has some problem. Some PSUs old PSU pulse the power for a few minutes and then automatically go into standby without a heavy loaad on them. Or the PSU/ HDD Brushless controller maybe damaged. Try the other jumper blocks/get another HDD/ change your PSU. Hope this helps!! Kabir
dream-
dream-
12 years ago on Step 4
Hmmm the HD I tried won't spin, but the motor makes a noise and it vibrates when plugged in. Am I missing something?
mhkabir
mhkabir
Generally this means that the controller/PSU is damaged. I faced this problem with several of the older HDD models I used. What model PSU are you using, ATX? MicroATX and BabyATX have some problems with the HDD sander. Or is it a commercial BT PSU? Try changing jumper blocks and see if that solves the problem. Try using another working HDD with the PSU. If it spins up, then the old HDD is damaged.(Coils burnt out by over voltage, bad controller etc.) Maybe the PSU is damaged and is spiking the power. One of my HDD burnt up after using it with a damadged PSU. So, I used another old Seagate controller from anothjer HDD to solve the problem. Hope this solves the problems. Kabir -- Geek Level 5
dream-
dream-
Thank you Kabir. The PSU is fine, works with other devices without problem. I suspect a microcontroller problem, since the motor vibration seems pretty strong (which would indicate healthy coils). One thought I had is if the HD made a check of the IO heads controller in order to spin, but then there would not be any motor vibration at all. I will have to try another HD.
mhkabir
mhkabir
I am always here if you need any more help. Hope yopu've rated the instructable!!
Kabir
dadu2007
dadu2007
Reply 6 years ago
Tengo problemas..Se para luego de 10 segundos?
jackowens
jackowens
8 years ago
Awesome idea, I am going to try this!
nulldbully
nulldbully
9 years ago on Step 4
My HDD's jumper pin socket has only 4 columns of pins. Your picture here has 6 columns. where shall I connect my jumper socket? I'm using a Seagate ST340823A and Seagate ST36422A HDD's. I also want to subscribe to you, how is it done? Thanks.
Sir__Walter
Sir__Walter
10 years ago on Introduction
I have made one that works quite nicely.
Although when ever I apply too much force, the motor automatically shuts off.
How can I fix this?
offtherails2010
Well done for this EXCELLENT & AWESOME 'ible mhkabir !!!
i just didnt know what to do with my collected 12 dead hdd's (Not working as a HDD as-in dead, lol) !!!
So now i'll have 4/5 sanding hdd's with different grade sandpapers, a metal grinding hdd and a polishing/buffing hdd !!!
A true work of inspirational GENIUS !!!
Once again many thanks mhkabir for the 'ible and taking the time to properly document this with really great photos and videos !!!
!!! ***** KEEP UP THE GREAT WORK ***** !!!
poolshark162006
poolshark162006
13 years ago on Step 4
 i really want to do this, but all i have are those ocz 60gb ssd's i opened one, and was no motor or anything inside of it... maybe ill try the 30gb one
NateHoy
NateHoy
SSD drives work a little different with this project.  What you want to do is cut open each memory chip and replace the each of the electrons with a grain of fine sand.  Then when you want to sand, write all "1" then all "0" repeatedly to the drive, and the sand will move around at great speeds and sand the wood.
The advantage of this approach is that, with proper addressing of the sand grains, you can actually sand patterns into the piece.  You should be able to write a program that can even "monogram" the wood with a little effort (warning, writing the program in lisp will mean every "S" will be replaced with "TH", just so you know).
