Introduction: Recycled Newspaper Clock
This clock is made from recycled newspapers again. I tried to do something different and easy. I made it in about 5 hours with drying. Searching on internet I found that this one is unique.
Step 1: Making Rolls
I made rolls from newspaper cut to dimensions 30cm x 10cm (about 12in x 4in). I rolled them on BBQ bamboo sticks with 1.5mm (about 0.06in) thickness. For the ring I use 12 rolls and for inside part 26 rolls.
Step 2: Bending Ring
The ring was bend around 24 cm (about 10in) pan. Glued and paint in dark color.
Step 3: Making Inside Part of Clock
Inside part made from 26 rolls, glued and cut to meet the ring.
Step 4: Final Assembling
Put together two part and glue them.
For the mechanism I drill hole in the middle of the inside part of the clock.
Insert the mechanism.
Step 5: Remarks
Dimension are not critical you can make it with different dimensions and colors.
At the end I saw that the clock hands should be different color to be seen easier.
