Introduction: Recycled T-shirt Wrapped Faux Pumpkins
How to make the easiest fabric wrapped pumpkin
Fabric wrapped faux pumpkins are all the rage!
Today I am showing you how to make the easiest fabric wrapped pumpkin ever.
Step 1: I Love Pumpkin Crafts
I know you have seen the sweater wrapped pumpkin and the flannel shirt wrapped pumpkin but today I am showing you how I have recycled an old t-shirt to do this with no sewing or glueing!
I just love cute pumpkin crafts!
Remember when I made this simple velvet pumpkin two ways
or
how I wrapped a faux pumpkin in fluffy yarn
I could go on and on about all the easiest pumpkin crafts I have made!
Step 2: Supplies Needed
Supplies needed for fabric wrapped pumpkins
Dollar tree foam pumpkins
Recycled stretchy t-shirt in fall colors
A real pumpkin stem (or use a stick or a piece of driftwood)
Hot glue (only for attaching stem)
That is it my friends!
Seriously it does not get any easier or cheaper than this!
Step 3: Prep Your Faux Pumpkin
First you need to take off the ugly green stem of the faux pumpkin.
It is styrofoam and attached with a toothpick. So pop it right off.
Next you are going to make a hole in the center.
You can use your finger to just enlarge the space to about an inch and half.
Step 4: Using Your Recycled T-shirt
Cut out a large square of fabric from your t-shirt.
Test to make sure all parts of the fabric will reach the center of the pumpkin.
Step 5: Attaching Fabric to Middle of Pumpkin
Place your pumpkin smack dab in the middle of the fabric.
Begin to wrap or rather stuff your pumpkin by pulling up the edges of your t-shirt fabric all around and stuffing it into the hole.
Be careful not to make the hole too much larger as you stuff.
You want to make sure the stem will cover the opening.
Tip-kind of gather the fabric as you go to create little pleats.
You are almost done! Can you believe it!
Step 6: Adding the Stem
Now all you have to do is add the stem.
I found a perfect stem at the pumpkin patch laying on the ground so I kept it knowing I would find a use for it.
The stem was a perfect fit over the opening of the pumpkin.
You could use a stick or a piece of driftwood for the stem if you can't find a real stem.
I simply used a little bit of hot glue to attach it right over the fabric and opening.
TADA! Done! Easiest fabric wrapped pumpkin around!
Step 7: Finished Recycled T-shirt Wrapped Pumpkin
Think of all the fun t-shirts out there at thrift stores just waiting to be turned into a beautiful fall pumpkin!
It is kind of like a Cinderella story don’t you think?
Rags to riches
Ok maybe I am stretching it a bit but I still love love how this one turned out!
