Introduction: Table Lamp From Scrap
Hello friends welcome to my another project. In this project i'm gonna show you how to make a table lamp using a scrap things like a dead headphone.
It's a rechargeable by the way.
So let's get started.
Step 1: Circuit Diagram and Components
You'll need
2.2k resistor with red led
3.7 volt Li-ion battery
1 watt led bulb
1n4007 diode
female connector
on/off spst switch
dead headphone
Step 2: Disassembling and Fitting
Open your headphone you'll need only left side of the headphone. Make a circuit according to circuit diagram and fit into the left side of the headphone. You don't need to pass a wire through microphone its already present in it simply remove the microphone and just replace with the 1 watt led. Fix the female connector on the right side of headphone's hole and fix the red led as a indicator on the other side of the headphone.
Step 3: Finish
After fixing the all parts now finally your table lamp is ready to use.
I hope you guys like it.
