Red Dot Sight Archery Mount
5,539
40
Introduction: Red Dot Sight Archery Mount
This is my first instructable so please go easy on me, if you have any questions or concerns please feel free to leave a comment below.
Step 1: This Is My Final Mounted Red Dot Sight
it probably cost me $50 to make, and that's only to buy the red dot sight. I already had all the metal.
Step 2: Making the Rail
This was the hardest step for me because I had to make a rail that would work for my red dot sight that uses a Weaver style mount. I wanted to keep it cheap so I made my own but you can buy them at a local sports store or off of eBay.
I used an old drawer slide that I had laying around. I took the inner sliding piece that had all the ball bearings in it and bent the sides into a triangle
Step 3: Building the Right Angles
The red dot sight had to be aligned with the flight of the arrow so I had to off set it a bit. This was achieved using a flat piece of metal.
Step 4: Getting a Good Distance
You want to have the red dot sight as close to you as possible so you can see the dot better, but you also don't want it to be too close because then you won't be able to put on the lens caps when your not shooting.
Step 5: Getting the Right Height
You need a good height so that you won't wreck your arrows when you shoot them.
Step 6: Try It Out
This is pretty simple, have a piece of metal that has a right angle on it and screw on the mount.
Step 7: Try It Out
Be careful!!!
It may not be sturdy so don't knock it on anything!
but now that your finish head down to the archery range, take some shots, and enjoy! :D
NOTICE:
I am not responsible for any injury or broken equipment. Always shoot in a safe area and never point your bow at anyone. Please be sure that the red dot sight is out of the arrows path before shooting. Over all, just be safe, smart, and have fun making your own Red Dot Sight Archery Mount!
2 Comments
6 years ago
Hello I was just thinking about your instructions. I am thinking about making a take down bow from snow skis. My thought was of adding a cheap dollar store laser to the bow. This was I have a take down bow with laser sight. What is your thoughts on this.
Reply 6 years ago
I think it will be super hard to make a dollar store laser accurate for a bow, and to make it stay on with the vibrations. Also you may not be able to see the dot at any distance that you would be shooting at. It might be a fun and cheap thing to try though.
