Introduction: Refinish a Rusted Exhaust
Like some of you out there, I've decided to take on a nice motorcycle rebuild project and everything's coming together nicely, except for a butt-ugly exhaust that sticks out like a sore thumb! The 30 year old chrome plating is flaking right off of the headers and the un-coated crossover pipe looks like it might be on it's last legs due to all the accumulated rust.
I've gone through many different refinishing steps in the past, from wire brushing, to naval jelly, to finally giving up and dousing the darned things in RustOleum! The results have been time consuming and completely inconsistent.
This tutorial details a pretty darned easy way of dealing with rust, scale, and flaking chrome, all with nearly identical final finishes. You can also apply the same steps to furniture, bumpers, or anything else that sits outside and corrodes.
Step 1: Sandblast!
The key to making this process easy is sandblasting. I can not stress this enough. Skip the solvents, the gels, the wire brushes...stick to plain old abrasive blasting. Heck, if was good enough for the Grand Canyon, it's good enough for you!
Different abrasives and grits are available to cover just about any refinishing project. Generally, Aluminum Oxide tends to be the best all-rounder. In the case of this steel-based project, I chose 60 grit, since my prior attempts with finer grits met with failure. Ultimately, you're looking to use a grit that will abrade the finish without stripping away the metal underneath.
You can see from these detail shots that the texturing on the metal still retains the telltale pockmarking from the prior rust. Also, all the rust has been easily removed from difficult crevices like welds, text, and flanges. The intention is to take it down to clean metal and remove all the rust so it won't resurface later. Abrasives are fairly cheap, so experiment until you find the one that works best for your needs.
For those of you bemoaning the lack of a professional sandblasting booth, there are many cheaper, portable, options available online that don't even require one (but they make a terrible mess, so use them outside). A quick Google search or a few minutes on HarborFreight.com should find you what you need. Remember, the abrasive does the work, not the quality of the gun!
Step 2: Powdercoat!
This is the easy part. A $69 Harbor Freight powder coating gun and about 25 bucks worth of high-temperature powder from PowderBuyThePound.com, is all it takes to completely re-coat an entire exhaust system (one pound of powder goes a very long way), and you can reuse the gun for future projects!
You could always go the cheap route and get high temperature spray paint from the hardware store, but I've found the finish to be thin and not very durable. In fact, I've had very poor longevity even using this paint for it's intended purpose - outdoor grills. Powder coat is only slightly more expensive and imminently longer lasting.
If you don't have a dedicated powder coating oven, you can just as easily use any home oven that goes up to 450 degrees. I would seriously consider not cooking in it again until you clean it out, but powder coating is a very low VOC process and off gassing is minimal so cleanup really isn't that bad.
Now, make sure you use High Temperature powder! They are completely different from the normal powders in that they're silicone based and rated from 600 to 1200 degrees operating temperature. Normal powder can only handle up to about half that.
Looking at the final finished parts, you can see the texturing the rust has left behind on the crossover pipe, whereas the header pipe is silky smooth. It would be even smoother, but since I knew I was dealing with a rust-pocked surface, I opted for "Muffler Black" which has a slight wrinkle finish.
That's it! I got down to bare metal, the rust is gone for good, and the results are beautiful. Experiment on your own and enjoy.
James Irmiger
Lead DC - Facilities Manager
TechShop SOMA
www.techshop.com
James Irmiger
TechShop SOMA
www.techshop.com
