Reframe: Turn Old IPhones Into Wall Clock or Wall Art!
Intro: Reframe: Turn Old IPhones Into Wall Clock or Wall Art!
Do you have an old functional iPhone that’s sitting around collecting dust? It’s a completely functional super-advanced mini-computer with a wonderful screen, speakers, microphones, and a ton of sensors built in. I set out to find an elegant way to repurpose them, and one solution I found is this: building a “frame” around it — I call it “the Reframe.”
While the possibilities with what you can do with the Reframe is endless with all the apps out there (or if you are so adventurous, you can write your own app), the two basic uses I found are: 1. a really nice-looking wall clock and 2. a really nice-looking wall art.
You phone has poor battery life? No problem! You leave it plugged in — just like an appliance. It draws about 2 watts on average. It even has a backup battery in case the power goes out!
STEP 1: Pick Your Weapon: IPhone 3G/3GS or IPhone 4/4S
This matters because the dimensions of these different models vary slightly.
Sorry, no iPhone 5 or 5S dimensions for now. But stay tuned for the next revision!
STEP 2: Cut Out the Faceplate
No matter what iPhone model you have, the faceplate will be the same. Cut a piece of opaque black 1/16” (0.06 in) thickness acrylic (or any thin material or color you might want to try) on a laser cutter, using the below template: FacePlate.ai
Basic dimensions are:
W 5 3/8” x H 5 3/8” with a 1 3/4” diameter circular hole in the center
(metrics) W13.65cm x H13.65cm with a 4.45cm diameter circular hole in the center.
If you don’t have a laser cutter, you can use a drill press with a circle cutting tool. If you use a black matte board, you can even try cutting it by hand with an Exacto knife!
STEP 3: Cut Out the Base Pieces
Cut the following pieces of MDF on the table saw. MDF can be bought at Home Depot or hardware stores. Alternatively, you can try birch plywood as well. Thicknesses might vary slightly, but that’s okay.
iPhone 3G/3GS
1. (1/4” thick MDF) - 5 3/8” x 5 3/8” (13.65 cm x 13.65 cm)
2. (1/2” thick MDF) - 5 3/8” x 3/8” (13.65 cm x 0.95 cm)
3. 2x pieces of (1/2” thick MDF) - 1 3/8” x 4 5/8” (3.5 cm x 11.75cm)
4. 2x pieces of (1/2” thick MDF) - 2” x 3/8” (5 cm x 0.95 cm)
iPhone 4/4S
2a. (1/4” thick MDF) - 5 3/8” x 3/8” (13.65 cm x 0.95 cm)
2b. (1/8” thick MDF) - 5 3/8” x 3/8” (13.65 cm x 0.95 cm)
3a. 2x pieces of (1/4” thick MDF) - 1 1/2” x 4 5/8” (3.8 cm x 11.75cm)
3b. 2x pieces of (1/8” thick MDF) - 1 1/2” x 4 5/8” (3.8 cm x 11.75cm)
4a. 2x pieces of (1/4” thick MDF) - 2” x 3/8” (5 cm x 0.95 cm)
4b. 2x pieces of (1/8” thick MDF) - 2” x 3/8” (5 cm x 0.95 cm)
STEP 4: Glue the Base Pieces Together
You can sort of guess which pieces go where, but if you get lost, see the diagram. I used Tite-bond wood glue, but I’d say Elmer’s glue would even work. Wipe off any excess glue with wet towel. Be sure to try putting the iPhone in as you assemble these pieces to make sure it fits. Be careful not to make it too tight, as the sleep/power switch shouldn’t be pressed down permanently. Clamps or big clips can help hold things together. Wait patiently for the glue to dry (just like Max the dog).
STEP 5: Sand and Paint
Once the glue is dry, lightly sand the frame with 100-grit sand paper, sanding block, or a power hand-sander. If you want the edges to look neat, you can put on spackling paste or wood putty, let dry, and sand again.
Then paint the frame black, or whatever color you want. If you use plywood instead of MDF, you might even consider not painting it at all.
STEP 6: Build in Some Hanging Options
If you plan to hang the Reframe up with a double-sided foam tape, then skip this step.
Other than a double-sided foam tape, there are a ton of ways you can hang this up. The easy option is to get a picture frame hook loop, or a keyhole hook for picture frames. A sawtooth hanging technique could work too.
If you want permanence and durability, you can even drill the entire frame into the wall. Be sure to counter-sink the screws, so that the acrylic piece with the hole in it would sit nice and flat on the wooden frame.
Note: based on my experience, the clear mounting squares don’t work that well hanging the whole Reframe on the wall (it works great with holding the faceplate in Step 8 though!).
Unless you have a USB extension cord, be sure you hang this near a wall outlet. Ideally, the Reframe would sit just a little below your eye level.
STEP 7: IOS Settings + Apps
On your iPhone, go to Settings > General > Auto-Lock > Never. This will prevent the phone from ever turning off. Also, under Settings > Display & Brightness, be sure to turn off Auto-Brightness and set the level of brightness you want.
Here are some ideas for apps you can run on the Reframe:
- If you want to use the Reframe to display a series of images, you can use the native Photos app and run a slideshow. Additionally, you can edit timing, repeat, and shuffling options under Settings > Photos & Camera.
- If you want to use the Reframe to display time, with your iPhone connected to the internet, go to the App Store and download a clock app. I found the Wake Alarm Clock - Free app to be the most elegant of all. The paid version has a different color ring.
- If you want to use the Reframe to display an endless video loop, try a free app called vloop. It’s not the best interface, but it does the job.
Depending on your iOS version, you might have to update the OS before downloading some of these apps.
STEP 8: Putting It All Together
Finally, place the iPhone with the desired app loaded in the frame, keeping it plugged in to the adapter/outlet. Place 4x 3M/Scotch Removable Mounting Squares on each corner of the Acrylic piece, then place it over the frame. Hang the Reframe up. And done!
16 Comments
mick2roo 7 years ago
Awesome concept. Thinking of a gallery piece but only playing when someone steps into view. A motion sensor activated. Thoughts on how this can be done?
TamirT1 8 years ago
This is cool! Regarding the camera app, let's say I want my photos to run in a loop, correct me if I'm wrong, but because of the round hole all my photos will be cut, correct? Thanks!
brucedenney 8 years ago
do you have to take it apart to restart it if the power runs out or ... does the touch screen work through the frame, or is it set to auto load... or something else.
2BlueBulls 8 years ago
The potential capabilities for this enclosure is endless, from iOS, Andoid or Windows mobile devices...especially with new handoff features, larger storage capabilities and screen sizes built into mobile devices.
When I first saw your instruct' the first think that popped into my head is a cheap home video security camera, depending on front facing camera specs.
Super nice design, I'll certainly be making this one.
purincess 8 years ago
DylanD581 8 years ago
Way cool! Do you think this will work with iPod touches?
BrownDogGadgets 8 years ago
This is awesome. I'm going to have to make one this weekend, and finally put that old iPhone 4 to some good use.
hertzgamma 8 years ago
Ingenious! :D Voted!
r1dd1ck913 8 years ago
Will this work with an original iPhone?
nodcah 8 years ago
The original iPhone is the same size as the iPhone 3GS, so just follow the directions for the 3GS and it'll work out the same!
nodcah 8 years ago
This is a great idea! And it looks really good too! Not much more you can ask for XD
SSS777 8 years ago
hey i think this is a great idea. i was wondering if there is any compatible notification app for this????
What kind of notifications are you thinking about? Maybe I can help you look for that app.
tomatoskins 8 years ago
This is beautiful! I love this approach of creating something new out of something that is just hanging out in a drawer.
