Reinforced Elfy Glue
Intro: Reinforced Elfy Glue
I am sharing this instructable with you guys because once someone else shared it with me. It is about glue and bonding stuff. So i have reinforced glue (chemical name: Cyanoacrylate) with the sponge that comes in the bottom of an ordinary cigarrette (Message from my country's government, CIGARETTE IS INJURIOUS FOR HEALTH) and the results are mind blowing, i mean you get a very hard and tough joint between anything that you want to join. I give an invitation to those who would research on the strength of such a joint.
STEP 1: Things Required
For this inscrutable, you will need:
- A good quality glue with formula listed in introduction.
- Cigarette (Unsmoked or smoked, both will work the same).
- And anything BROKEN.
STEP 2: Getting Things Ready...
- Make a hole in the glue bottle with the help of a paper pin.
- Break off the filter from the cigarette.
- Remove the paper around the filter of cigarette.
- Adjust the shape of filter according to the need of your joint.
STEP 3: Applying the Glue
- Put the sponge on the joint.
- Apply the glue over the joint.
- NOTE: Use safety goggles because the glue and sponge will generate fumes.
- Now wait for a while so the fumes settle down and so the joint is repaired.
5 Comments
jtobako 7 years ago
congratulations, you've made fiberglass : )
mrhudson47 7 years ago
I learned this trick in Thailand from my auto mechanic. ..He uses cotton wadding (cotton Ball)
Seems to work as well... he needed to repair a lot of the plastic post and other interior parts of my car
tytower 7 years ago
This is called a filter and it is better not to use a used one as the oils and tars will affect the ability of the glue to stick.
Danyal Muhammad 7 years ago
Thanks for correction because i didn't knew the exact name of filter so i made it up to be "cigarette sponge". And also i have made joints with used cigarette filter which work quite well.
Darsktar38 7 years ago
