Introduction: Rejuvenating Sharpie Permanent Markers
About: Retired Firefighter 1966 to 1986; Retired Wheat Farmer 1987 to 2003. Drapery Sales 1969 to 1987. 21 year Quintuple Heart Bypass Surgery Survivor; 18 year Melanoma Cancer Survivor. 86 years young.
It seems that Sharpie pens have a very short life.  I buy one and the next time I try to use it, it is dry.  I read another Instructable on rejuvenating the big fat colored Sharpies using acetone and decided to try it on the one pictured.
What I did was just make a quick dip into the acetone and remove it.  It worked.  I was able to finish the project I was using the Sharpie on.  I don't know how long it will last, but it saved me a trip to store today and that is good enough.  Finger nail polish remover containing acetone should work also.  I hope this helps someone else.
I like projects that cost $0.00   :-)
4/7/14 Edit:   I tried Petrucci's method of refilling Sharpies with hypodermic of 2ML of acetone.  I injected it at the rear through the plastic case.  I pushed it through with syringe empty, pulled it out and filled it with the 2ML acetone and then injected it.
BE CAREFUL & DON'T INJECT YOURSELF.
It takes quiet a bit of pressure to push the needle through the plastic, so there is a danger of bending or breaking it. I found the needle penetrated better if you turn it while applying pressure.  I plugged the hole with Dap silicone calk when I finished.
4/9/14
The injected pens are working as good as new or better than new.  This has been a great experiment, and with the help of
Petrucci, it has been very successful.
