Safe Pressure Cannon
Intro: Safe Pressure Cannon
Parts:
1 In. Female Threaded Anti- Siphon Valve www.orbitonline.com/products/Valves/02/16/07/1827/
1" male to 1 1/2" or 2" female black pipe bushing
Threaded 1 1/2" or 2" 3' long black pipe
1 1/2" or 2" black pipe end cap
male schrader valve stem
18" long 1" black pipe
24v battery
24v buzzer
toggle switch
momentary switch
connector wire
tools:
Teflon tape
pipe wrench
5/8" drill bit and drill
glue (Preferably hot glue)
electrical tape
bike pump
pipe dope
24v battery
24v buzzer
toggle switch
momentary switch
connector wire
tools:
Teflon tape
pipe wrench
electrical tape
bike pump
pipe dope
STEP 1: Asembling the Tank
The first part is the tank. your tank needs to be made of black pipe otherwise it will explode when you pump it.
1.first take the end cap and drill a 5/8 in. hole in it
2.attach the valve stem and tighten in place
3.screw the end cap to the 3' long 2" (or 1 1/2) pipe
4.use the 1" male to 1 1/2" or 2" female black pipe bushing to attach the anti-siphon valve to the 3' long 2" (or 1 1/2) pipe
STEP 2: Wiring
here is how I did the wiring
STEP 3: Barrel, Presure, and Ammo
Good setups:
1" barrel, 3/4" cork, 40 psi
3/4" barrel, paper ball, 50 psi
3/4" barrel, wet paper ball, 40 psi
2" barrel, snow, 40 psi
2" barrel with coupling, snow with tennis ball in coupling, 50 psi
2" barrel, stun grenade, 20 PSI(www.instructables.com/id/stun-grenade/)
Paulv186 6 years ago
Part of me wants to build one of these with an identical white pipe for the pressure chamber. I'm gonna go out on a limb and say you probably did that already and it didn't go so well.
