Introduction: Reloading .223 Ammo for an AR15 (or Other Rifle)
Reloading .223 for AR15
The process of reloading is a delicate one, care must be given as you work with firearms and especially as you make or reload ammunition. Like with building the AR15 you really need to read all you can, and then even after that still consult with a professional to be sure you are safe and accurate.
When I was first learning how to reload, years ago, all I really wanted to start with was a parts list, or a tool list. So here is my tool list:
Lee 3 die set – sizing die, Powder loading die, seating die
- Lee crimping die
- Lee universal depriming die
Lee 4 hole turret press
Lee pocket primer cleaner
Lee Chamfer tool
Lee .223 sizing tool
Lee auto disk powder
Lee safety primer for small rifle primer
- Lee auto disk powder upgrade – this allows you to stack two disks, this is required for the amount of powder you will need to load into a .223 casing.
Lee case lube
Steal wool and cloth to clean casing with
I also like to have a ammunition holder, I like to have two that hold 50 rounds each so I can reload 100 rounds at a time, I like to clean the press and dies after 100 rounds, I will need to do a page on how I do that as well.
Step 1: Components of Ammunition
I like my lists so here is another one, this is the components of a single round of ammunition:
Primer
Brass Casing – you can buy ammunition that has steal casing but you can’t reload a steal casing with this equipment.
- Powder – make sure you get a powder that will work with .223, your die set will come with some options, and you should already be talking to a trusted knowledgeable realoader.
- Bullet or projectile.
The question might come up, which part is the most important or which component will affect accuracy the most, the answer will be all of it, and including all the components of the rifle.
Now lets get down to business, how to actually reload, or rather how I do reloading, since like almost everything there are many ways to achieve the same end. First is the cleaning of the brass casing, obviously if you purchased new brass you skip this part. This is my least favorite step in the realoading process.
Step 2: Step 1 - Pop Out the Spent Primer
Step 3: Clean the Primer Pocket
Step 4: Resize the Casing
Step 5: Smooth the Cut Edges of the Neck
Step 6: Clean and Polish the Casing.
Step 7: Casing Lube
Step 8: Sizing Die and Primer
Step 9: Powder
Step 10: Seat the Bullet
