Introduction: Remote Bluetooth Firework Igniter
Wouldn't it be nice to ignite more than one firework at the same time? Or even have a safe distance to more dangerous explosives. In this project I will show you how to build a circuit which can do just that with the help of the Bluetooth functionality of your smartphone. Let's get started !
Step 1: Watch the Video!
The video gives you an overview of what you need to do to build something similar. In the following steps I will present you more in depth information about it.
Step 2: Order Your Parts!
Here you can find all the parts that I used during this project (affiliate links):
Ebay:
4x XT60 Male+Female Connector: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x ATmega 8-16PU:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 28 Pin DIP Socket:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x FTDI Breakout:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x HC-06 Bluetooth Module:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
3x 0.5W White High Power LED: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Toggle Switch:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 7.4V Li-Po Battery:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Fuse (30A):http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x LM7805 (5V Regulator):http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Crystal 16MHz:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
3x IRLZ44N N-Channel MOSFET:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 2-Component Adhesive:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 1µF Capacitor:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x 22pF, 3x 100nF Capacitor:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
6x 150Ω, 3x 680Ω, 1x 3.3kΩ, 1x 4.7kΩ, 4x10kΩ Resistor:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
10Ω (1/4W) Resistor as Igniter:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Male Header:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Female Header:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Perfboard:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
10m 3x0.75mm^2 wire:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Aliexpress
4x XT60 Male+Female Connector: https://s.click.aliexpress.com/e/_d7rt0sn
1x ATmega 8-16PU: https://s.click.aliexpress.com/e/_dYaDsKm
1x 28 Pin DIP Socket: https://s.click.aliexpress.com/e/_dWGvKh4
1x FTDI Breakout: https://s.click.aliexpress.com/e/_dV4Gqp1
1x HC-06 Bluetooth Module: https://s.click.aliexpress.com/e/_dVorgZM
3x 0.5W White High Power LED: https://s.click.aliexpress.com/e/_dT3EvA6
1x Toggle Switch: https://s.click.aliexpress.com/e/_d9dxPD5
1x LM7805 (5V Regulator): https://s.click.aliexpress.com/e/_dXSrfiP
1x Crystal 16MHz: https://s.click.aliexpress.com/e/_dZTspL4
3x IRLZ44N N-Channel MOSFET: https://s.click.aliexpress.com/e/_dWhSrDl
1x 2-Component Adhesive:https://s.click.aliexpress.com/e/_dXim8Nk
1x 1µF Capacitor: https://s.click.aliexpress.com/e/_d7dOwRz
2x 22pF, 3x 100nF Capacitor: https://s.click.aliexpress.com/e/_dU4FEsB
6x 150Ω, 3x 680Ω, 1x 3.3kΩ, 1x 4.7kΩ, 4x10kΩ Resistor: https://s.click.aliexpress.com/e/_dTPpXjt
10Ω Resistor as Igniter: https://s.click.aliexpress.com/e/_dTPpXjt
Male Header: https://s.click.aliexpress.com/e/_dWOKAy2
Female Header: https://s.click.aliexpress.com/e/_dWOKAy2
1x Perfboard: https://s.click.aliexpress.com/e/_dXx2Zv5
Amazon.de:
4x XT60 Male+Female Connector: http://amzn.to/1LUS0HX
1x ATmega 8-16PU: http://amzn.to/1g6Wi3n
1x 28 Pin DIP Socket:http://amzn.to/1LUS3DD
1x FTDI Breakout: http://amzn.to/1LUS4HA
1x HC-06 Bluetooth Module:http://amzn.to/1f3nUyT
3x 0.5W White High Power LED:-
1x Toggle Switch:http://amzn.to/1vi1UsA
1x 7.4V Li-Po Battery:http://amzn.to/1LUSgGM
1x Fuse (30A):http://amzn.to/1LUSldz
1x LM7805 (5V Regulator):http://amzn.to/1LUSmyj
1x Crystal 16MHz:http://amzn.to/1LUSqOs
3x IRLZ44N N-Channel MOSFET:-
1x 2-Component Adhesive:http://amzn.to/1g6WEXG
1x 1µF Capacitor: http://amzn.to/1LUSygR
2x 22pF, 3x 100nF Capacitor:http://amzn.to/PD2jZj
6x 150Ω, 3x 680Ω, 1x 3.3kΩ, 1x 4.7kΩ, 4x10kΩ Resistor: http://amzn.to/1g6WLT3
10Ω Resistor as Igniter: http://amzn.to/1IVKFmS
Male+Female Header:http://amzn.to/1IMwUZK
1x Perfboard: http://amzn.to/1EMeDyA
10m 3x0.75mm^2 wire: http://amzn.to/1IVKTdC
Wago Terminal: http://amzn.to/1g6X1Bu
Amazon.co.uk:
4x XT60 Male+Female Connector: http://amzn.to/1EMl6Kb
1x ATmega 8-16PU:http://amzn.to/1g71lkl
1x 28 Pin DIP Socket:http://amzn.to/1EMlk3J
1x FTDI Breakout: http://amzn.to/1UyozCY
1x HC-06 Bluetooth Module:http://amzn.to/1g71rbL
1x Toggle Switch:http://amzn.to/1EMlAjf
1x 7.4V Li-Po Battery:http://amzn.to/1UyoI9k
1x Fuse (30A):http://amzn.to/1EMlGrd
1x LM7805 (5V Regulator):http://amzn.to/1g71B2V
1x Crystal 16MHz:http://amzn.to/1UyoJu2
1x 2-Component Adhesive:http://amzn.to/1IVOUyL
1x 1µF Capacitor: http://amzn.to/1IVOVTt
2x 22pF, 3x 100nF Capacitor:http://amzn.to/1PYRTf8
6x 150Ω, 3x 680Ω, 1x 3.3kΩ, 1x 4.7kΩ, 4x10kΩ Resistor:http://amzn.to/1NzxNJR
10Ω Resistor as Igniter:http://amzn.to/1XFOqb3
Male+Female Header: http://amzn.to/1GN5xMt
1x Perfboard: http://amzn.to/1TlDGwj
10m 3x0.75mm^2 wire: http://amzn.to/1XFOLKV
Step 3: The Wiring!
Here you can find the schematic and pictures of how my final circuit and wiring inside my project box looks like.
Step 4: Program You ΜC!
Use the Arduino IDE and my sketch to program your ATmega.
Step 5: Download the App!
Here you can download the .apk file for your Android phone or the .aia file to import the project in your account of the MIT App Inventor.
MIT App Inventor: http://appinventor.mit.edu/explore/
Step 6: Success!
You did it. You just created your own Remote Bluetooth Igniter!
Feel free to check out my YouTube channel for more awesome projects:
https://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
