Introduction: Remote Controlled Hovercraft
ss
Step 1: Gather Construction Materials and Tools
aa
Step 2: Gather Electronic Materials
ss
Step 3: Creating the Construction
- ss
Step 4: Motors Placement and Functionality
ssss
Step 5: Power Supply
ss
Step 6: Electronic Scheme and Soldering
ss
Step 7: Arduino Code
ss
Step 8: Final Look and Functionality
ss
First Time Author Contest
28 Comments
1 year ago on Step 8
Nesecito de tu ayuda no logro entender como controlarlo
2 years ago on Step 8
What is the flexible skirt made of?
Answer 2 years ago
Exactly. I know it's a lot of extra work, but including a BOM hot link really helps sourcing the parts. Even if the link might not be for our country.
Reply 2 years ago
The instructable has been updated and the necessary parts now are linked to websites where you can purchase them.
Answer 2 years ago
Hello there, the flexible skirt is a nylon material. To give you an idea of where i took mine, i cut it from a kitchen apron, there as many kind of aprons that are made of nylon and knowing that in kitchen there might be accidents with boiling water, those nylon aprons have a good thickness and durability. I will also update this information in the steps above. Thank you for commenting!
2 years ago
Very nice! You made it to hackaday, congrats :)
Did you try use it over water?
Reply 2 years ago
Hello there, thanks a lot ! I just saw it and I'm really happy about that.
Yeah i have tested it on water, but when i placed the hovering motor in the base i made sure its not too deep into it, that way the motor connections won't touch the water. And make sure you don't stop the hovering motor until you remove it from water just for safety reasons. But with some improvements in the future i might replace it with a water resistant DC motor, or design some casing for it, so whomever makes this project won't bother about that.
Thanks again!
2 years ago
Love it. Will try and post it here.
Reply 2 years ago
Lovely! Ask if you will need any additional information.
2 years ago
Very good!
But never solder a lithium battery !!!
There is plastic foil inside.
Reply 2 years ago
Hello there, yeah i am actually building a high-amp spot welder for connecting lithium batteries so my future projects will be more professional. Thanks for your feedback!
Reply 2 years ago
Thanks the answer!
I wait for your next project!
Norbert
2 years ago
cool, can you explain a little bit how does the boat is inflated? Since the motor is face horizontal, rather than downward in your design.
Reply 2 years ago
Hello there, the project works with two motors, the motor faced horizontal as you mentioned creates the thrust power so the hovercraft can move forward. The other motor creates the hovering power, i attached an image (see point 1,2) that is the motor placed for inside the base. You can take that type of dc motor from hair dryers, as they already have the proper and its casing as the motor i used.
2 years ago
Really great idea. Only there is several BAD THINGS! In schematic mosfets are shown connected in reversed drain source way. In connection like this motors will run ALL TIME, with no control. Use of linear regulator for power motors is very bad thing! In this way you just loosing power on this regulator from (18-12)*1=4W to (24-12)*1.5=18W. There can be used any cheapest suitable DC/DC converter like with LM2576.. Another possibility - direct powering from batteries with PWM modulation to reduce power to level of 12V (maybe with battery voltage sensing). Finally - use of Li-ion batteries without BMS circuit is really DANGEROUS!
Reply 2 years ago
Hello there, I tried making the project functional with the things that i already had during quarantine, as a lot of components are not arriving from online orders because of the current pandemic. I also ordered a 6S BMS for the batteries so when i have the components i will be improving the project and update my instructable as well.
Thanks a lot for your advice, i will be improving the project as soon as possible.
2 years ago
nice work man!!
2 years ago
Nice work bro
2 years ago on Introduction
Your genius man proud of you
Very useful idea
