Introduction: Remove Kaspersky Antivirus Using Kaspersky Wizard Removal Tool
If you are using Windows XP, Windows visual image or Windows seven, a program is bundled with the software system to form it easy to get rid of programs from your computer: the Add/Remove Programs tool. Add/Remove Programs may be an easy, stepwise tool to get rid of almost about any program from your pc.
First, click the beginning button at the left aspect of your task bar, and choose instrument panel, once the instrument panel window comes up, click the link for Add or take away Programs. This can cite the Add/Remove Program tool in an exceedingly new window. Wait because the program list populates, as a result of the load time can increase in accordance with what number programs you've got put in on your pc.
Make sure the kind by drop-down confine the upper-left corner of this window is sorted by Name so scroll down the list to the K section, and realize Kaspersky during this list. Highlight Kaspersky and click on the take away button or call Kaspersky technical support 1-855-205-0915.
This will cite the uninstall wizard, which can walk you stepwise through removing the program.
Other easy thanks to take away Kaspersky from your pc is to use the take away Tool bundled with the Kaspersky software system. It, too, is straightforward to use and straightforward to search out.
First, click the beginning button on the left aspect of your task bar and choose All Programs. The list can pop showing all the programs you've got installed; realize Kaspersky during this menu. Hover over the Kaspersky icon, and within the sub-menu, click Modify, Repair or take away.
In the Modify, Repair or take away window, click the take away icon. Within the next window, you will have to form a choice: to utterly Uninstall or Save Application Objects. A whole Kaspersky uninstall can take away everything associated with Kaspersky from your pc. Save Application Objects can permit you to stay your knowledge if you are change the software system to a more modern version. You will need to confirm that you simply keep your activation knowledge (so you do not need to get the software system again), the threat info, the anti-spam info, backup files, quarantine files and iSwift files (so you do not need to transfer of these files again).
  • Click the take away button. The program can work on its own to get rid of the files necessary, and can advise you once complete.
  • When the program processes are complete, click OK.
  • Restarting PC when Removal Done
Kaspersky Anti-Virus will not utterly uninstall Kaspersky till once you've got restarted the pc -- there are variety of files employed by your software system within the background and that they will not be deleted till not in use. Make certain to shut all the windows, and choose restart from the beginning menu.
Once your pc has rebooted, Kaspersky are utterly uninstalled from your pc, and you'll be able to either install another antivirus software system, or update Kaspersky to the most recent version.
