Remove the Write Protection on a Micro SD.
1,309,649
26
140
Introduction: Remove the Write Protection on a Micro SD.
When I got my phone I got it for the mp3 player. What I didn't know is that they expected me to buy a $30 connector cable. I tried to be the smart consumer and just bought a Micro SD card with an adapter. I plugged that bad boy into my computer only to find out that it was write protected. I figured out the painfully obvious way to unlock it.
Step 1: Adapter
The adapter is the size of a normal SD. Plug the micro into the bottom.
Step 2: The Easy Part.
Using an air can (or just your lungs) blow into the adapter, plug in the card and DO NOT lock it into place. Just stick it in there and hope it stays. You may now have your way with the card.
140 Comments
4 years ago
super guide for removing the write protection on micro SD. Here another complete guide if you want to know airtime fairness ON or OFF
5 years ago
Hey just checked this guide on Sd card write Protected
5 years ago
here you can check out how to remove write protected from memory card.
5 years ago
here you can check out post on how to remove write protection on micro sd card
5 years ago
I honestly thought you were making fun of us when I saw the solution. Then I saw another review and thought 'oh well, no-one will know, what have I got to lose'? I had to blow into the adapter a few times but it worked! Thank you so much.
5 years ago
6 years ago
If you have any damage mciro sd memory card. don't throw away. you can fix it. Fix Damaged micro SD Memory card
Reply 5 years ago
yea, how? dumbass you didnt even say how to "Fix Damaged micro SD Memory card"
5 years ago
Tnx for this.. so genius! Im such an idiot. Almost decided to format.. hahah
5 years ago
Heya,
Checkout this :- Sd card write Protected
6 years ago
i didn't get the solution , how can i comment
6 years ago
Thanks a lot for this, this worked quite well
6 years ago
hi
I have same problem with my 4 GB mico SD card used in my phone, I format it with almost every software that I could catch , but after successful task done format message , all my old files come back with no change, is my disk currupted or I could fix it
6 years ago
Watch this ultimate guide on how to remove write protected from micro sd card
6 years ago
6 years ago
you can also check out this step guide on how to remove sd card write protected
6 years ago
this is for kids it doesn't helps out
i have a 32Gb micro SDHC card plugged directly in card reader and says card id write protacted there is nothing in between card and card reader no switch nothing
6 years ago
thanks for sharing this amazing post but it don't solve my problem completely so i cam across this post which solved my very much hope it will help you too. http://www.streamingl.com/2015/12/how-to-remove-memory-card-card-password/
6 years ago
thanx a lot a tried all the methods but it worked
6 years ago
i dont have an adapter, can i use my phone then plug it in my pc instead?
