Introduction: Renesas RA6M4 With MPU6050 Driver
Below is the professional technical translation of the provided text about porting the MPU6050 driver to the Renesas RA6M4 platform:
Recently, I acquired an RA6M4 development board through Renesas' official website. Since I still had some leftover sensors from university projects, I decided to use this opportunity to get started with Renesas MCUs.
Preparations
Current Renesas RA-series MCUs are ARM-based and can be developed using IAR or Keil. However, the best support for all features comes from the official e²studio IDE paired with FSP (Flexible Software Package). For those familiar with STM32:
  1. e²studio is analogous to Keil 5 (IDE).
  2. FSP is similar to CubeMX (graphical configuration tool).
Hardware: Renesas EK-RA6M4 development board and an MPU6050 accelerometer. Software: The official MPU6050 driver sourced online.
Step 1: Create Project
After installing e²studio and the FSP plugin:
  1. Create a new RA project.
  2. Select the EK-RA6M4 development board during setup.
  3. FSP pre-defines I/O for onboard peripherals.
  4. For custom/third-party boards, choose "Custom User Board" and specify the chip model.
  5. Proceed through the prompts to finalize the project. e²studio will auto-open the FSP configuration interface.
Step 2: FSP Configuration
Key configuration tabs include:
  1. Summary, BSP, Clocks, and Stacks (where peripheral modules are managed).
  2. Add an I²C module for MPU6050 communication:
  3. Navigate to Stacks → New Stack → Connectivity → I2C Master.
I²C Configuration Properties:
ParameterValue
Slave Address
0x68
Address Mode
7-bit
Callback Function
i2c_callback
Interrupt Priority
Configure as needed
I/O Pins
Board-specific
After configuration, click Generate Project Content to auto-generate driver code.
Step 3: Project Structure
Generated directories include:
  1. ra/ & ra_gen/: Renesas BSP and FSP-generated drivers.
  2. src/: Main application code (entry point).
  3. configuration.xml: FSP settings (double-click to reopen FSP).
  4. Developer Assistance: Drag-and-drop APIs (e.g., OPEN, read, write) into your code. Parameters are pre-filled!
​编辑​
Note: Compared to CubeMX+Keil, e²studio streamlines development by integrating IDE + graphical configuration + API drag-and-drop.
Step 4: Porting MPU6050 Driver
  1. Copy the official MPU6050 driver files into src/.
  2. Replace original I²C functions with FSP-generated equivalents:
  3. Example: Replace I2C_Write() with g_iic->write().
  4. Initialize I²C in main() and call MPU6050 APIs.
