Introduction: Renovative: Ball Machine Elements
Step 1: Ball Storage
Step 2: Tracks
Step 3: Lift
This is your ordinary chain lift. It has been changed, tested and replaced only a couple of times. It is nothing fancy, but just regular. Please note: Sometimes it is very hard to make a chain lift, so always have backup ideas in mind for when the lift does not work.
Step 4: Starter
The starter ( what I call it ) is the beginning of the balls journey through this big ball machine. This element has a short slide then a green flexi rod slide. This element is designed to give the ball a little force before moving on.
Step 5: Path Switcher
You all know the basic purpose of the path switcher and what it does. This path switcher has a small chance that it will stay on that path 1-2 times. Trust me, I've tested it and it happened couple of times.
Step 6: Drop-and-roll! Path 1
This is my Drop-and-roll! knex element. It is kind of like a dropper, but afterwards, it rolls on, on the element! Thas how it work!
Step 7: Hole Drop, Path 2
It drops through a hole and drops onna wheel dropper and heads to the lift. Simple.
Step 8: Push Up Lift: Path 2
Although this is a lift, this is an ending-type lift, meaning a lift at the end of the path.
