Introduction: Repair IQ700 Siemens Washing Machine Door Handle
In this short instructable I show you how I repaired the door handle of my Siemens iQ700 washing machine. The door handle has a small part which operates the actual door locking mechanism, this part broke off.
You need the access to a 3D printer
Step 1: Open the Door
Our washing machine was closed when the part of the door handle broke off. The first challenge was to open the door. Thankfully someone posted a Youtube video of the ways to open the door.
The door was easily dismantled by removing all the torx screws. Beware of the heavy glass bulb in the door.
Step 2: Designing and Printing the Part
Glueing the broken part will never be strong enough to withstand the force in the future. Therefore I designed a part which would be stronger. For the designing proces, I glued the broken part back on to be able to measure all the dimensions. I designed the part in Fusion360. The stl file is attached
I printed the part in PETG (Wellhan grey) because this material is quite strong.
Step 3: Mounting the Part
I sanded the part and sanded the handle part before I glued the part to the handle.
Firstly I glued it very weakly to be able to fit the part in the door. Because it fitted perfectly, I glued the part thoroughly with 502 cyanoacrylate glue.
After drying of the glue I screwed the part to the handle to strengthen the connection.
Reassemble the door.
