Repairing Broken Wheels on Plastic Storage Bins
Intro: Repairing Broken Wheels on Plastic Storage Bins
Plastic wheely bins are great. Stuff your stuff in 'em, and easily move them from one place to another.
They're not so great when the wheels break off.
The wheels on the bins I have at work are one solid piece of plastic, axles and all, that snap into little hollows on the underside of the bin. Over time the plastic nubs wear down, and eventually break right off, making the bins that much more annoying to transport. This Instructable will show you how I fix this.
Skill: Some
Time: Not much
Skill: Some
Time: Not much
STEP 1: Assemble Materials
Required
- Bin with broken wheel
- A nail just a bit narrower than the wheel axle. Round nails are best, but square works too.
- A torch (butane torch pictured, but I ended up using my larger propane torch)
- Pliers
- Small bench vise
- Calipers
- Drill
STEP 2: Prepare the Wheel
Two ways to do this step:
Option 1
Option 2
Option 1
- Secure the wheel in a vise.
- Grab the nail with pliers.
- Heat the nail in a torch flame.
- Use nail to melt all the way through the wheel.
- Clean the melted plastic off of the nail.
- Reinsert the nail and check that the wheel rolls.
Option 2
- Measure the nail (on the diagonal if it's a square one).
- Find a drill bit that is slightly wider (or start smaller and work up a little at a time).
- Drill all the way through the wheel.
- Clear away the plastic curlicues.
- Insert the nail and check that the wheel rolls.
STEP 3: Prepare the Bin
Heat the nail and melt holes where the wheel axle lines up with the sockets to the sides of the wheel well.
STEP 4: Prepare the Nail
If the nail is longer than necessary, it's time to fit it properly.
- Put the nail all the way through one of the holes.
- Mark off the required length.
- Trim to fit.
- File down any burrs.
STEP 5: Put It All Together
- Put the nail partway through the hole from the outside of the wheel well (in this case, from the inside of the bin).
- Thread the wheel onto the nail-turned-axle. Might take a bit of fiddling to get it on there, depending on size and shape of the bin.
- Get it properly situated in the wheel well, and the nail lined up with the other hole.
- Push the nail the rest of the way through.
And my boss wanted to just toss these and buy new ones. Ha.
rimar2000 10 years ago
Very good repairing work.
