Repairing Charger
Intro: Repairing Charger
Hello! guys today i'm gonna show you how to repair your charger at home very easily but before do this you'll need to know how to soldering if you didn't know keep practicing.
STEP 1: Disassembling
Let's get started open your burnt charger with screw driver.
STEP 2: Examine
Examine your charger kit what types of component burning and simply replaced it.
STEP 3: Components
These are the components burnt on my charger kits i just simply replaced with new components
Capacitors: 2.2uf(400 volt) and 4.7uf(400 volt)
Resistors: 100 ohm
STEP 4: Replacing
After replacing my charger kit is just looks like this and its work fine.
I hope you guys like it.....:)
11 Comments
ilesanmimoses2020 2 years ago
Phil B 8 years ago
Asadullah Mughal 8 years ago
yes you are right sir but its fine its just black color on it by burnt the others i already checked it.
MikB 8 years ago
'"tis just a fleshwound!"
The bulged capacitors are clearly shot, so good job on replacing those.
The others don't look bulged to me, but, if they are using the cheapest capacitors possible, and two have clearly failed, the others may be out of spec but not yet bulging and leaking.
Always try and use decent quality capacitors for this, they might be a few pence more, but it means you won't have to do it again in a year or so!
Nice repair.
thanks MikB
By the way thank you very much sir Phil B
padbravo 8 years ago
Yeap!
simple, clean presentation
thanks padbravo i hope you like it
chelseabun 8 years ago
Don't you check diodes?
All diodes in good condition.
Good. It's bad if just repace damaged component without checking all diodes ( I thought you don't check them) :)
