Introduction: Repairing Rubbermaid Reveal Spray Mop Pump
This is a great design but with a crucial flaw. If you go to the Rubbermaid website and look at the Reveal's user reviews mostly everyone loves the mop but has the same complaint - the unit stops spraying. It's often blamed on the handle/trigger but it's actually the pump plunger/piston that binds and gets stuck in it's cylinder. You will need to open the pump case and pull the assembly out. Once you get it out you'll see it's actually pretty simple with not many parts to worry about. It is a bit fussy to reassemble but not at all complicated.
Tools: Long Phillips (star) screw driver with a small head. Very thin flathead screw driver. 120 grit sandpaper.
Step 1: Locating the Pump Chamber Screws
You will need a long, thin, Phillips (star head) screw driver. The Reveal has 3 screws holding the main pump body. You can easily see the 2 on the body and 1 right where the stem meets the mop swivel head.
Step 2: Remove Screws and Separate Pump Body
Once the screws are removed the pump body can be split open. Use a thin flat head screw driver and do this slowly - do not just bust it open as you may damage parts. Pay close attention to the inside parts. You will need to wiggle down the spray pump nozzle casing sleeve (red) that also acts to hold the 2 pump body panels in place.
NOTE! You do not need to separate the pump case all the way down to the bottom where the stem meets the red swivel for the mop head. The screw here needs to be loosened off enough for you to be able to separate the main body above it.
Step 3: The Pump Body and Parts
Lay out the parts just as you see here. It is important to understand how these simple parts work together. You don't need to completely take apart every little piece.
It is helpful to know that the red cone shape attaches to the outside liquid container (where you put in your cleaning solution).
The silver rod with 2 holes is the mop handle. It attaches to the pump plunger/piston. Keep this in mind for later assembly.
Step 4: Fixing the Pump Plunger (Piston)
The problem is that the plastic pump plunger/piston sticks in the cylinder. Use 120 grit sandpaper and EVENLY sand the circumference of the plunger head and the 2 ribs below it. Test. Repeat until there is better movement but NO loss of suction.
Photo 2 shows the plunger/piston sanded so it works nicely in the cylinder without having taken off too much material - you do not want to take off too much. It doesn't need to be super pretty smooth but sanding too rough and uneven will not keep suction. Sand a little at a time and test it at each and every attempt.
When you are satisfied put a small amount of petroleum jelly (Vaseline) around the plunger/pistons head and ribs.
Step 5: Assembly
Hold open the pump body casing and align the pump parts into the grooves supplied inside. This isn't hard and makes sense as you move them into place ... take your time.
Notice in the 2nd and 3rd photos the mop rod (that connects the handle to the pump body). It has another rod inside that attaches to the plunger/pistion to make it go up/down in the cylinder. This needs to connect properly to the top of the plunger/piston AND be properly seated into the pump casing.
Test your assembly by simply placing the 2 pump body casings together - they should fit tightly and the trigger should work the pump smoothly.
Once you are satisfied everything inside fits properly put the pump case back together, careful to line it up so it fits perfectly snug with no gaps and the entire pump assembly is seated and secure. Tighten up the screws.
Your mop has been saved from the garbage. I've tested this for about 6 months and still going strong no problems. Happy mopping!
9 Comments
4 years ago
This works great. It's fun to be able to fix something rather than throw it out. Thanks for the clear, concise, well-documented, and effective instructions, LenTurbo500!
6 years ago
I made it!! thank you!
6 years ago
Thanks for this! I just repaired mine.
7 years ago
YES! thank you! this helped me repair my mop, i was worried i was gonna have to trash it.
Reply 7 years ago
that's awesome thanks for posting :)
Just so happens our second one finally started malfunctioning in the same way ... it's on my to-do list.
Cheers, Len
7 years ago
I appreciate the help - my mop works a ton better now! I did want to note, that the screw drive you need is a Philiips screw driver, but NOT a star head. Also, the Reveal has FOUR screws holding the main pump body. The 4th one is under that red sleeve that you need to slide down.
Reply 7 years ago
Thanks for the update Shelley. The models we have are a few years old so sounds like the newer ones have an added 4th screw under the red sleeve. Otherwise I'll assume all the internals are the same ... and still not working properly! Regardless, nice to hear it worked. Ours is still operating nicely after 9 months from repair date.
8 years ago
?????FN A++
8 years ago on Introduction
Nice clear instructions. Thank you for sharing! I hope we see more from you in the future.
