Repairing a Vintage Electrovoice 664 Microphone
11,611
54
12
Introduction: Repairing a Vintage Electrovoice 664 Microphone
About: I'm an actor/tech/IT/graphics/editor/writer kind of guy. I do a fair share of voice over work and have the full time gig at Bard College at Simon's Rock. While waiting for machines to do things, I hit the wo…
Once you get a reputation for working and building cool things... more cool things come your way.
So, this is what happened. I helped a friend out with his computer, nothing fancy, upgraded his OS and added more RAM. Simple stuff.
He shows up with this pitted, rusted busted Electrovoice 664 and says, "I figured you could do something with this..."
Step 1: Step 1. Break It Down.
So it wasn't working. Nothing, no signal at all.
There's a screw holding the top screen on and then all the rest of the element and filters came out in succession.
Step 2: Step 2. the Parts Bin
Ok, I do a LOT of scrounging and scavenging. I don't throw much away. Anyhoo.
I had this element from a Sennheiser e835 wireless microphone. The microphone had battery corrosion issues and was destroyed. But I saved the element, the housing, and anything else that looked cool. Because you never know when I have to build another Lightsaber or SOMETHING.
Unscrew the top of the Sennheiser, and the element was sitting in a rubber isolation gasket. I cut around it to free it from the rubber cement.
Step 3: Step 3. Test Fit.
OMG, LOL and whatever else....
It FIT LIKE IT WAS MEANT TOO! Seriously. It dropped in and sat pretty. I let out a squeee!
Step 4: Step 4. Break It Down Further.
So the reason the original element was broken was mostly due to corrosion. My friend did say he found it in a pile of leaves in the back of his shed. (I want more access to this "shed")
So I took everything else apart.
Step 5: Step 5. Sandblasting
Ok, I'm not going to lie. It's cool having access to a sandblaster.
Ten minutes with some 100psi sand and it cleaned up nicely.
Step 6: Step 6. Restraint...
It was at this point I was going to paint it. Wild thoughts ran through my head of Ferrari Red, or bug yellow. Something bold.
But then I thought it should be more subtle, not call more attention to itself than it already will. Bold lines with sophisticated pizazz.
The first coat was self etching primer on the aluminum housing.
This filled in some of the pits remaining from sandblasting.
We let that dry then used a nice pewter metallic.
Step 7: Step 7. Cleaning Up Other Bits
Some light sanding took care of the rest of the grime from the screens. A combination of 600 grit sandpaper and a small Dremel wirewheel. I protected each piece with a coat of clear lacquer when done.
Step 8: Step 8. the Switch Plate
Grubby.
I scanned the switch plate, and then found an image online to guide me.
In Illlustrator, I recreated the label and printed it on some water decal paper. Fun stuff, you print it on a color photo printer, seal it with acrylic clear spray paint, cut it out and slide it onto the object after soaking the print in water. Just like old fashioned model making, putting that darn fighter jet together...
Step 9: Step 9. Circuit Test
At this point I temporarily connected things to make sure that everything functioned. Sennheiser element to switch and transformer into the cable and so on.
It worked. Cool beans.
Step 10: Step 10. Reassembly!
I soldered the wires together and used some E6000 silicon adhesive to mount the element in the housing. I used a couple of plastic pieces to hold it center while it dried.
I then cut the end off an XLR cable, and soldered it to the 4 pin Amphenol connector that fit the microphone. I could have changed out the connector, but I like the idea that the microphone is switchable from Lo-Z to Hi-Z by changing pins. Plus it's geeky cool.
Once dry, I put in the side screen, the pop screen and screwed in the center mount. I still can't believe this is all fitting together so nicely.
For a pop filter, I pulled the filter out of the Sennheiser element and cut it down to fit inside the 664's screen.
Step 11: Step 11. Beauty Shots!
It came out fantastic!
And to hear how it sounds, click HERE
This microphone will hit the stage!
Be the First to Share
    • For the Home Contest
    • Game Design: Student Design Challenge
    • Big and Small Contest
    12 Comments
    Freakedeke
    Freakedeke
    11 months ago
    Good day!
    Nice project! i basically got the same mic, might be another edition of it, but still a model 664.
    I have a SM58 that i would use to mod the 664, but had a couple of question from checking your instructable.
    First, how can you detach the bottom part from the top (at the hinge) ? even with the hinge screw removed, it seems impossible to pull apart.
    2- when i pull off the 664 element, there is a 'board' attached to it with what seems to be a capacitor and 2 transformers, did you connect the new element to that board, or removed all of it and took the 'board' from your seinheiser?
    Thanks so much in advance!
    Frank
    monkeywork
    monkeywork
    Reply 11 months ago
    Hi Frank, Good question. I would experiment and see which sounds better. I used the 664 board and switch, since it only had a transformer and a capacitor. (filter) The parts from the SM58 are usually sealed in plastic, but you should be able to port them over to the new microphone.
    as far as the hinge goes, keep working it. it could be just stuck together.
    Freakedeke
    Freakedeke
    Reply 11 months ago
    thanks! :)
    Mbsz53
    Mbsz53
    Question 2 years ago on Step 9
    Were you able to remove the 4pin female connector from the mic with one little screw? Some are permanent. How tough was it to remove? Thanks
    monkeywork
    monkeywork
    Answer 2 years ago
    I actually left the 4 pin connector, and just wired my XLR to three of the pins.
    Mbsz53
    Mbsz53
    Reply 2 years ago
    How difficult would it be too remove and replace? It looks like there is just a small screw holding it in, but you never know how else it may be secured or the routing of the wire. Thoughts?
    Thank you for taking the time.
    Merry Christmas! 🎄🎆
    monkeywork
    monkeywork
    Reply 2 years ago
    The single screw sounds right. remove that, and unscrew the two screws holding the switch in as well. Then everything should slide out.
    monkeywork
    monkeywork
    Reply 2 years ago
    If you look at step 9, you'll see that the connector does indeed come out. From there you can cut and install a new one with XLR connections. It should come out with the rest of the switch and transformer.
    ronhummel
    ronhummel
    Question 2 years ago on Step 11
    Anyone know the secret of how to open up an Electro Voice 676 in order to replace a dead element?
    Edbed
    Edbed
    7 years ago
    Awesome
