Introduction: Replace Coil Springs (the LOW-COST Way)
SOMETIMES you can have a broken coil spring and not even know it. The cars not quite driving right but you’re not sure why. One trick to verifying a broken spring is to look at the other side and compare. Putting a new spring on your car isn’t hard when you understand the basic concepts. In this video I go through the basics so you can feel confident to safely install coil springs. Hope you enjoy the video.
Step 1: Take Out the Assembly
Start by putting oil that looks like it needs it. Then take out the all the bolts and take out the assembly
Step 2: Take the Strut Assembly Out of the Cover
If you use a impact hammer to take out the bolt that holds the strut in to the cover it will save you a lot of time!!
Step 3: Take Off the Old and Broken Spring
Decompress the old spring by ratcheting the compressor tool off.
Step 4: Put on the New the New Spring
Compress the new spring And put it on the strut and put the strut bolt back on.
Step 5: Reassemble Everything
Make sure you put Anti-Seize on all of the bolts before you put them all back on you will thank yourself later. Use a jack to push the holes into place and put the bolts back in.
