Introduction: Replace Outlets and Extension Cord Plug
First adopters likely invested the extra $500 - $1000 to install a dedicated 220V level two charging plug at their house. Second-hand people, such as myself, have a harder time justifying that investment. I have been charging my Leaf overnight on the included 110V "trickle charger". I don't have outlets at the end of my garage, so I have to plug the charger into an extension cord.
By the way, my house was built in 1974. Fun fact! Electrical outlets wear out. Sometimes that's annoying, because your phone charger keeps falling out. Other times, it's deadly. See, a funny (it's not actually funny. I'm employing a literary device) thing happens when an electrical connection gets loose. The resistance gets higher as more current tries to flow through a smaller contact patch. Do you know how electric heaters work? They pump a ton of current through really thin (high resistance) wire. Outlets and extension cords are made of plastic. Plastic is really awesome stuff. It's very versatile. It can also catch, impressively, on fire. I don't want that in my garage. Nasty stuff, fire. (also likely a large contributing factor to the evolution of the human brain. True story! Look it up.)
Anyway, apparently my car was drawing too much current for my old outlets and it heated up the outlet and plug. I had to replace them, or risk catching my garage on fire.
Step 1: Find Your Breaker Box, Turn Off the Outlet
Step 2: Unscrew the Outlet Cover and Outlets
This part should be pretty straight-forward.
Step 3: Remove Wires From Old Outlets
For this style of outlet, this is annoying. The wires are shoved into the roundy holes on the back of the outlet. There is a slot above and below the respective holes. You have to simultaneously shove a flat bladed screwdriver into the slot and pull the wire out at the same time. Don't stab yourself with the screwdriver when everything slips out of your hand. Take note of which color wire goes into which hole. You're going to want to copy that arrangement when you put the new outlets in. Probably. They might have done it wrong. Use an outlet checker before you unplug the old one to see if they did it right. Yes, that is out of order. This is why you read all of the instructions before you start.
Step 4: Screw the Wires Into the New Outlets
Look how shameful that old burned plug is. Select your shiny new plug. My shiny new plug has push-holes in the back so that you can conveniently shove your wires in without having to use a screwdriver. If your situation is similar to mine, those convenient holes are useless. I don't think the gauge of my wiring is that large (small? 12 gauge is thicker than 14 gauge, because confusing relationships make you respect people who understand them more?), but it is too thick to fit in the quick connect holes. Bend the wire into a J hook and put the hook around the screws on the new outlets. (that sentence took 1/100000th the time that the actual task takes, and is 2000 words shorter than the transcript of expletives that will come out of your mouth in the process)
Step 5: Shove It Back in the Hole, Screw It, Test It
I mentioned that I don't feel like my wires are that thick. They sure seem thick, though, when you are trying to bend and shape them by shoving your outlets back into the hole from whence they came. Make sure you aren't shoving things in such a manner that insulation is compromised. Screw the outlets in. Now you have to ask yourself how much you believe you did everything correctly and nothing is touching anything that it shouldn't be touching. Clench your buttocks a little, and flip the circuit breaker back on. No pops? The breaker didn't snap back off? That's good. Now take your tester and plug it into your new outlets. Your tester. Yes, the outlet tester that you have. Seriously, you are working on high voltage stuff here. I should have told you to buy one at the same time as you buy the new outlets. I'm telling you now, and you are reading all the instructions before you start, right?
OK. That's sorted. If the tester shows that your wiring is correct, screw the outlet cover back on. Again, if you are like me, it will be old and inflexible. Despite your best efforts to keep the replacement outlets centered in their correct positions, the outlet cover will still crack when you squeeze it over the top of the outlets. That's how you know you did it right.
Step 6: All Done! J/K, LOL, the Extension Cord Plug
Awesome contemporary colloquialisms aside, don't forget that the plug end on your extension cord also has heat damage. Remember? See, look at that picture. The brass is discolored and the plastic is melted. Luckily, when you are buying your replacement outlets and your outlet tester, you can also buy a replacement plug like the one in the picture. Isn't it cool?
Step 7: Cut the Plug Off of Your Cord
That's not a euphemism. As you can see in the first picture, I have my diagonal cutters positioned. As you can see in the second picture, that first picture was a lie because I actually cut the cord in a completely different spot.
Step 8: Check Which Color Goes Where
Use your multi-meter on the continuity setting to check which color wire goes to which tine of the plug. Your continuity meter. The one in your toolbox. Look again. Really? OK. Buy one when you go to buy your outlets, plug, and outlet tester. This is getting expensive. Are you sure you don't just want to hire an electrician? Also, maybe ask him how much it would cost to wire in a 220V outlet for a stage two electric car charger.
Edit: As pointed out in the comments (and by my dad), Green should go to the rounded ground pin. White should go to the larger neutral blade, and black should go to the hot narrow blade. Also, if I was being extra careful about whether the extension cord manufacturer did this correctly, I should have been checking continuity from the other end (the unchopped one) of the extension cord.
Step 9: Strip Your Wires, Insert, Screw
Step 10: Screw It All Down
Once the wires are securely screwed in, screw the case closed on your replacement plug. Looks great! Hopefully now your garage won't catch on fire. There are other steps you could take towards this end, such as using sheetrock (gypsum board? drywall? what are the kids calling it these days?) instead of plywood, but that would be a project for another day.
Step 11: What You Might Need
Since you read all of the instructions before you started doing anything, it's fine that I'm waiting until now to tell you what you might need to complete this project.
- Screwdrivers (phillips and flat)
- Replacement outlets
- Replacement plug for extension cord
- Multi-meter with continuity test function
- Outlet tester
- Wire stripper (or scissors and a box knife and a very experienced hand)
Optional:
- An electrician
- Money to pay the electrician
