Introduction: Replace the Touch Screen (Digitizer) on a Palm TX
When the touch screen on a handheld device goes out, you're in big trouble. It pretty much turns your expensive electronic toy into a paperweight. Fortunately, with twenty bucks and about half an hour of your time, you can fix one of these yourself. I'm not sure what the insides of other handheld models look like, but the Palm TX was a very simple fix.
Just a quick disclaimer: I am not responsible for any damage you do to your device or warranty. There are plenty of little fiddly bits inside one of these things that can be easily damaged through carelessness or accident. Also, I'm pretty sure if you open one of these yourself you invalidate the warranty. You have been warned.
***UPDATE 8/4/09:
I forgot to mention, you should probably try PhilB's instructable on the crazy digitizer problem first--you may not need a new digitizer at all! It didn't work for me, but after I'd installed the new touch screen, the DigiFix program was better at calibrating the new screen than the basic software.
***UPDATE 5/4/10: If you've repaired your Palm using my instructable, go into the Notepad and write, "Thanks depotdevoid!" or something along those lines. Take a picture of it and post it to the comments below, and I'll send you a DIY patch!***
***UPDATE 8/4/09:
Step 1: Get a Replacement Digitzer
Ebay was the best place I found. It took me a few minutes to figure it out, but apparently a "Touch Screen" is actually known as a "Digitizer." I found mine with a search for: digitzer+palm+tx. There were several different options, but being the cheapskate that I am, I bought the one that ships direct from Hong Kong for $19.99, shipping included. That meant I had to wait a couple of weeks for it, but I can be patient if I have to be.
The digitizer actually came in a kit that included a couple of screwdrivers and plastic prybars. I didn't need the screwdrivers, but the prybars certainly came in handy.
Step 2: Open the Palm
Okay, here we go, time to invalidate that warranty!
First, remove the four screws on the back, as shown below.
Secondly, use the prybars to open the case and remove the back. Be gentle! Everything will come apart without forcing it, just be firm and try different angles if you feel like you're applying too much pressure.
Step 3: Remove the Screen
Now that the case is open, you'll need to remove some parts to get to the screen. The screen is connected to the circuit board by a couple of flat connectors that pop off. Simply slip a fingernail under the connector on the side away from the wires, and pull up. They should come off with fairly gentle pressure.
The top of the palm (where the power switch is, thanks to user FM9295 for pointing out that this was a bit unclear) will pop off at this point, allowing you to remove the circuit board. Be careful, the power button on the top of the device is not actually connected to anything. I ended up spending some time on the floor searching for it.
Also thanks to user Tripp Hazzard for pointing out that in some models, the power button is actually attached to the top, so you may not run the risk of losing it!
The screen can now be removed from the case. BE EXTRA CAREFUL FROM HERE ON OUT! LCD displays are notoriously fragile and brittle, so use caution not to bend it in any way!
Step 4: Disconnect the Old Digitizer
The digitizer is connected to the screen hardware by one little four pin connector underneath some protective tape. Carefully peel back the tape just enough to uncover the wires and the connector. The connector itself is a small bit of plastic that consists of a white guide for the wires and a black clamp (thanks to user JOHNDWARD1 for pointing out that this clamp is sometimes not black, but should still pop upwards). Once you uncovered everything, simply slip your fingernail or a prybar under the back of the black part and pull up. It will fold up, releasing the wires. Make sure to keep the tape folded back so you can install the new digitizer.
Step 5: Remove the Old Digitizer
The digitizer is secured to the screen by thin strips of adhesive. Use the prybar to slide underneath the four edges of the digitizer, releasing it from the screen. BE EXTRA CAREFUL, the digitizer is slightly flexible, but the LCD is not!
Now is a good time to make sure you don't leave any dust particles on the screen, as once you've replaced the digitizer you won't be able to get them out again!
Step 6: Install the New Digitizer
Your new digitizer will have a bit of plastic on the back protecting the adhesive strips. Remove this and carefully align the new digitizer on the front of the LCD. Before you install it, make sure there isn't any foreign matter on the back side of the digitizer or else you'll be stuck with dust particles in the display for the rest of eternity.
Step 7: Put Everything Back Together
Now you simply go through all of these steps in reverse order: connect the wires to the four pin connector, fold the tape back in place, reinstall the screen in the case, reconnect the circuit board, clip the case back together, and put the screws back in. If you've done everything correctly, when you fire up the palm you should be able to recalibrate the digitizer and be off and running!
Step 8: Final Thoughts (updated 3/1/10)
I hope someone out there finds this instructable useful! I'm not sure how analogous this is to other brands/models, but I know that most touch screen technology is basically the same, so it shouldn't be a far stretch to do the same thing for your device.
Thank you for reading! Please take a moment to interact, as I greatly appreciate any comments, questions, ratings, or subscriptions you'd like to take the time for!
****UPDATE 8/3/09:
According to user PhilB, while he hasn't actually replaced a digitizer before, he has opened both a Handspring Visor and a Sony Clie. From what he's seen of my pictures, the insides look very similar, so replacing the digitizer on one of these units should be pretty similar to replacing it on the Palm TX.
***UPDATE 8/4/09:
****UPDATE 3/1/10
User stefpalmtx has noted that sometimes attempts to calibrate the screen when it's all buggy will screw up the calibration after you've replaced it with a new screen. If you install the new screen and it doesn't recognize any taps, don't despair! Try a hard reset first, that might just do the trick.
****UPDATE 1/1/11
User JOHNDWARD1 says that the DigiFix software didn't work for him, but a piece of software called PowerDigi did. This is pay to use software, but it does have a free trial you can use to see if it will work for you!
****UPDATE 8/3/09:
***UPDATE 8/4/09:
****UPDATE 3/1/10
****UPDATE 1/1/11
